FS: JL Audio Cleansweep
Old Oct 3, 2010 | 09:59 AM
sexyrob's Avatar
JL Audio Cleansweep
Price: $140 Shipped to anywhere in the US
Condition: Used - Good
Pickup Price: $125
Bought this used and ended up just buying a headunit and DD kit. It's in great condition and comes with all the connectors and cables. Would be a cheap way to add a amp to your factory head unit and get great sound.
If you don't know what cleansweep does, it digitally "cleans" the incoming signal of any mess created by the factory head unit and sends a excellent signal to your amp so you get a great sound that would otherwise be further distorted.
Specifications:
32BIT DSP PROCESSOR
ROTARY **** TO CONTROL THE MASTER SYSTEM VOLUME AT THE OUTPUTS OF CL441DSP FOR THE FACTORY(OEM) SOURCE OR AUXILIARY SOURCE
4CH SPEAKER INPUT FROM FACTORY(OEM) UNIT
SIGNAL SENSE ON/OFF SWITCH
OEM(SPEAKER) LEVEL INPUT : 1 - 4CH : 100mV, 30V RMS WITH FULLY AUTOMATIC LEVEL SETTING
AUXILIARY INPUT : 1 : 250mV, 4V RMS
FRONT & REAR RCA OUTPUT
EQ RESOLUTION : 1/3 OCT. 25 ~ 20,000Hz
MASTER VOLUME CONTROL UNIT WITH SIMPLE ROTARY ****
S/N RATIO : > 102dB
THD : < 0.01% AT RATED OUTPUT (20 ~ 20,000Hz)
SIZE : 4.37"W x 1.54"H x 9.72"L
click images for hi-res
feedback:
eBay
my350z
g35driver
date is so old because I've been trying to sell it for so long, I forgot about it and I'm relisting it. Since I can't bump my old thread.
Old Oct 19, 2010 | 09:20 AM
sexyrob's Avatar
bump
Old Oct 19, 2010 | 01:56 PM
Terribleone's Avatar
did you ever install this or move on to the other DD right away? I was just wondering how much of a difference it made over the stock head unit.
Old Oct 19, 2010 | 02:00 PM
sexyrob's Avatar
I only powered it up and tested each channel individually. not enough time to notice a difference over stock, but that was also because I was using stock speakers.
this is meant for someone who wants to get an amp and replace their ****ty speakers too.
without this your new speakers will sound pretty bad compared to what they could sound like.
Old Oct 22, 2010 | 01:35 AM
sonk55's Avatar
thats cheap
Old Oct 22, 2010 | 09:03 AM
sexyrob's Avatar
yeah been trying to sell it for awhile, dropped the price.
Old Nov 28, 2010 | 10:00 AM
sexyrob's Avatar
bump, someone buy this. I need brakes
Old Nov 29, 2010 | 09:25 AM
byte_me77's Avatar
Would this install before or after the factory amp?
Old Nov 29, 2010 | 11:02 AM
sexyrob's Avatar
before, you tap into the 4 channels the radio is putting out and then you can plug a normal amp into it, not that funky bose crap.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
