HELP! Audio gurus please come in. Just got new system installed!
Old 10-09-2010, 03:08 PM
hye_G's Avatar
thanks for the help everyone. i did setup the amp with the settings you mentioned Wrathernaut. Definitely sounding better now and that buzzing is much fainter though still there. heres a couple pics
setup
close up
new amp settings
how did my puppy get in here? lol
Old 10-09-2010, 06:14 PM
eggyhustles's Avatar
i would set rear and front to hpf and set it to 80
Old 10-09-2010, 07:36 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,037 Likes on 610 Posts
I just wanted to "zero" it out first, since lack of any midrange was part of the problem.
You're definitely not tuned at all, but at least you're not really missing anything.
Before setting any of the filters, get the gains set right.
Get a test CD (search online) to start setting gains.
Turn the radio to as loud as it goes before you start hearing distortion, then turn it back a little, leave the radio there.
Turn up each gain until you start hearing distortion, then back off.
Once your gains are set, then you can start doing the filters.
Since your sub is at 80hz LPF, setting the front and rear to 80hz HPF is probably all the tuning you'll need with that amp, the rest should be done at the headunit.
Oh, and leave the boost off, it's "more bass" not "better bass".
Old 10-09-2010, 11:21 PM
Yeah, bass boost just boosts a certain frequency which is what you don't want.
You want it to be completely flat.
Old 10-10-2010, 02:18 PM
hye_G's Avatar
thanks a lot guys
Old 10-10-2010, 11:14 PM
djCypher's Avatar
Was a return ground installed when the RCA's where ran?
Old 10-11-2010, 03:16 AM
17NickG35's Avatar
Where is that enclosure from? Install wires look un-tidy, but I'm meticulous. Good luck with your kappa amp. My Kappa 4 lasted 2 months.
Old 10-13-2010, 01:06 AM
hye_G's Avatar
zenclosures
EnCr1pt3d
07-08-2019 02:48 PM
mjfenix
08-17-2017 05:49 AM
noctilucous
2nd Gen (V36) Sedan
08-06-2015 08:47 PM
Cacoepy
08-03-2015 01:09 PM
Frostbite91
08-02-2015 04:59 PM
Quick Reply: HELP! Audio gurus please come in. Just got new system installed!
