6x9 subs?
Old Oct 12, 2010 | 11:22 AM
MP340's Avatar
6x9 subs?
Has anyone ever tried replacing the stock deck 6x9 with sub 6x9's?
http://www.tb-speaker.com/detail/1230_04/w69-1436.htm
Splice into the rear deck speaker wire turn it into RCA and run a amp for the read deck instead of a single sub in the trunk. I travel and use my trunk a lot, you know dead bodies and such...so having the trunk free is important but a little more bass would be fun. I know it wont be like a 12'' sealed box but it would be way more than stock right?
Old Oct 12, 2010 | 11:33 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
With that one only going down to 40hz, I wouldn't really call it a subwoofer, more like a mid-subwoofer. If you're putting in an aftermarket amp, you'll want to tap the pre-amp audio signal, not the ones going to the 6x9's.
But definitely would outperform the Bose 6x9's even with a moderate amp.
Old Oct 12, 2010 | 11:40 AM
MP340's Avatar
Ya I meant pre amps. Using something like this http://www.crutchfield.com/p_142SLC4...speaker+to+rca
Old Oct 12, 2010 | 12:04 PM
itgogitrev's Avatar
Do you have the Bose sub? If anything, I would replace the stock sub with an 8" free air under the package tray. You'd probably have a difficult time getting the bass you want out of the 6x9s for two reasons.
- No lower than 40hz frequency
- No real enclosure to put them in
I still would like to hear those sometime, they may work in my MR2.
Old Oct 12, 2010 | 01:26 PM
Originally Posted by Crutchfield.com
So you're trying to connect an amplifier without speaker-level inputs to a car stereo that doesn't have preamp outputs?
No.
No.
No.
You'd still have your audio ruined by the Bose amp's horrible EQ.
Save your money and ears and tap the pre-amp audio signals going into the Bose amp instead.
He's got the coupe, so it'd be a lot more modification to get an 8" free air on the deck than the 2 6x9's. But yeah, a 8" wouldn't be bad and take up little more room than one hooker's breast implant would use.
Old Oct 12, 2010 | 05:51 PM
MP340's Avatar
I thought in order to use the pre amp wires you needed to use an inline converter to get RCA out to the aftermarket amp?
Old Oct 13, 2010 | 04:31 AM
No, you just splice RCA cables into the pre-amp wires. The line output converter is for when you have speaker-level signals that need to go into an amp that only accepts line-level inputs.
Old Oct 15, 2010 | 05:12 PM
MP340's Avatar
So after seeing this post,
https://g35driver.com/forums/audio-v...lled-pics.html
I want to put a little sub in like a 8 maybe a 10. I dont care for a portable earthquake, just enough bass.
Would this sub
http://www.crutchfield.com/p_1368W1V...o-8W1v2-4.html
driven by this amp
http://www.crutchfield.com/p_136J225...-J2-250-1.html
be sufficient in a box about half a cubic foot next to the spare tire like that guy had?
g.spot
May 9, 2016 10:54 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
JustinMKN1
Sep 18, 2015 03:40 PM
Frostbite91
Aug 2, 2015 04:59 PM
