Bluetooth Microphone prolems
Old Mar 17, 2011 | 11:33 PM
  #31
gl35's Avatar
I ended up buying a Pioneer double din head unit, and people are still complaining "I can't hear you" so maybe it is this over priced phone I bought... I have had nothing but bad luck as far as bluetooth is concerned, so I just live with it.
Old Mar 17, 2011 | 11:43 PM
  #32
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by herrschaft
I'm assuming the microphone your using will work fine with the stock HU? I plan on splicing it onto the existing wires if so.
Should work fine.
Old Mar 17, 2011 | 11:45 PM
  #33
Where did you put the microphone?
Here's where I put the garmin microphone and have had no complaints:
Old Mar 17, 2011 | 11:47 PM
  #34
gl35's Avatar
I did not have good luck with that, but.... I believe that it has a lot to do with the phones brand of bluetooth chip being compatible with whatever it is pairing with.
Motorolla and Blackberry seem work best with most other stuff, but it is a trial and error process.
Just my experience tho, although the splicing of the microphone should work OK, I did not say it was a failure, just "not right".
Old Mar 17, 2011 | 11:48 PM
  #35
gl35's Avatar
I put mine on the inside of the pillar near the driver.
I'll go an take a picture.
Old Mar 17, 2011 | 11:55 PM
  #36
gl35's Avatar
OK, here is where i put mine...
Old Mar 18, 2011 | 12:21 AM
  #37
I put mine in the middle, since you only have turbulent air from the top of the car near the microphone, not the top and sides.
Plus my radios both have voice control of iPod and stuff, so it's good to have it hear both driver and passenger for voice commands.
I've considered hooking up a microphone to the computer and driving around with the mic in different spots and measuring for the quietest spot, but it's a bit of work and I'd need to be a passenger in my own car.
Old Mar 18, 2011 | 12:23 AM
  #38
gl35's Avatar
Maybe I will move it this weekend.... it can't hurt!
Thanks Wrathernaut.
willdogs
Dec 8, 2015 11:32 AM
1Typhoon
Sep 25, 2015 08:45 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
beevanhuynh
Jul 14, 2015 09:06 AM
