FS: Tang Band 6X9" Subs
I'll give it a bump, and remember there's always the US postal service flat-rate boxes, you might be able to get both in the $16-ish one.
How many ohms are these?
whats the lowest u could take shipped to 10975? im in NY. let me know. my one rear speaker just crapped out on me
Thanks Guys!
-WoW
I wanted to buy these exact speakers, drop them into the rear deck with an amp for a stock look with hopefully some additional bass. Will they fit in the rear deck of a coupe without too much modifying?
$100
Tang Band W69-1042J 6"x9" Subwoofer
The oval shaped frame of the W69-1042 gives you the surface area of a typical 8" driver in the footprint of a 6-1/2". Perfect for constructing a narrow-baffle subwoofer, or for automotive installs in factory 6" x 9" locations. High power handling and long excursion for excellent low-bass performance. Specifications: *Power Handling: 90 watts RMS/170 watts max *VCdia: 1-1/2" *Impedance: 8 ohms *Re: 6.5 ohms *Frequency range: 35-350 Hz *Fs: 35 Hz *SPL: 87 dB 2.83V/1m *Vas: 1.34 cu.ft. *Qms: 6.05 *Qes: 0.37 *Qts: 0.35 *Xmax 7 mm *Dimensions: A: 6-1/2" x 9-1/4", C: 4-3/16".
