Keep Sub Box From Moving?
Old Mar 17, 2011 | 01:59 AM
icrazy2u's Avatar
I took my 12's from my old car and going to put them into the G. Is there a way to keep the sub box from moving around without drilling holes in the trunk? If not, what are some really good cheap sub boxes for 2 12" Fosgates? Maybe one that still gives me trunk room.
Old Mar 17, 2011 | 10:03 AM
KPierson_'s Avatar
You can try velcro on the bottom of the sub box. On many cars the "hook" part of velcro will attach to the trunk carpet and make it very difficult to move the box around.
Your other option would be to install backstrapping (or plumbers strapping) to the box and try to find something up high to tether it to. Screwing down to the floor is difficult because the spare tire well is pretty big.
Old Mar 17, 2011 | 02:15 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
^ He beat me to it.
Velcro sticks quite well to our car's trunk carpet.
Old Mar 19, 2011 | 08:05 PM
icrazy2u's Avatar
Thanks, I still may need a smaller box.
Old Mar 19, 2011 | 09:22 PM
KPierson_'s Avatar
How much air space do your subs require? How big is your current box?
Old Mar 21, 2011 | 08:47 PM
icrazy2u's Avatar
I'm not sure about the air space, but the box is just a regular 2 12" sub box. Its to tall to fit in the trunk. It could only fit where the trunk opens and I still need a little bit of a trunk.
Old Mar 21, 2011 | 09:14 PM
KPierson_'s Avatar
There is no such thing as a "regular" sub box. The cubic volume of the box is extremely critical in the performance of your subs. Most sub manufacturers recommend a box that is +/- 10% of their recommended air space. So, for example, if you have two subs that need 1.5cuft a piece you will need a box that is 3.0 cuft, but a box between 2.7cuft and 3.3 cuft would work. 0.3 cu ft is equivalent to 12"x12"x4". Not a whole lot of space to play with.
There is an old saying that the worst sub in its ideal enclosure will outperform the best sub in its worst enclosure.
Old Mar 21, 2011 | 09:55 PM
maclovio's Avatar
^^^What he said! !
I ended just putting one 12 due to the air space required for the sub. I put matching carpet on the sub with no velcro or anything on the box. It doesn't really move. Plus i have it so that i can remove it whenever i need the space to carry stuff in the back.
Old Mar 22, 2011 | 01:01 PM
Gdriver90's Avatar
just drill into it, who gonna see?
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
