Removing plastic surround fro passthrough?
Old Apr 3, 2011 | 01:45 PM
G35xTurbo's Avatar
I'm currently removing the back deck to remove the stock Bose 8 so that i cam replace it with my JL sub but I can't seem to figure out how to get the plastic surround off from the passthrough. I've searched through the fsm but haven't been able to find anything else. Any help would be appreciated! Thanks!
Old Apr 3, 2011 | 03:57 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
You did completely remove the rear seats first, right?
After removing the screws and bolts that are visible, you just give it a good yank.
Removed mine the other week, and don't recall any hidden bolts or screws.
Old Apr 3, 2011 | 09:05 PM
G35xTurbo's Avatar
Ahh, I was hoping not to have to do that. My rearseats recline so i was able to uncover the back deck without removing the seats but just had the center passthroigh left. Any tricks to the seat? Hidden bolts or just clips? Thanks!
Old Apr 3, 2011 | 10:34 PM
The most hidden of the seat bolts are the ones that you get to through the armrest opening. It's easy to get with a extension connected to a wobble joint connected to a short socket, if you don't have that setup, it's a bit tricky to get at them.
You have to take out the seats first.
Arm rest second.
Side trim after that.
Rear pillar trim after that.
Then you can get the center pass through out.
Finally, you can get the rear deck off.
Old Apr 3, 2011 | 11:34 PM
G35xTurbo's Avatar
What a pain. Thanks for the tips. I have Wednesday off so I'll tackle it then. Thanks again!
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
