help me find strong 12V lead in trunk
Old Apr 17, 2011 | 12:12 PM
Alex07G35's Avatar
Hi guys a need to find a strong 12V lead in the tuck hopefully you can help me find it.
Thanks in advance
Alex
Old Apr 17, 2011 | 12:16 PM
chink-ah-saur's Avatar
why dont you just make one
Old Apr 17, 2011 | 12:21 PM
Alex07G35's Avatar
Making one would mean running a cable all the way from the battery to the trunk. Don't really want that.
Old Apr 17, 2011 | 12:23 PM
kennymo's Avatar
what do you plan on running on this 12 volt lead
Old Apr 17, 2011 | 12:26 PM
Yea but why would there be 12v runing to the back in the first place..and if you ran wire back there it wouldnt be interrupted
^amp im thinking
Old Apr 17, 2011 | 12:31 PM
Alex07G35's Avatar
bottle warmer.....
Old Apr 17, 2011 | 12:36 PM
F$%# aye bottle warmer, throw a stove in that sht
Old Apr 17, 2011 | 05:05 PM
Majiks's Avatar
run a 12v lead.... its not that hard, maybe take an hour or 2
Old Apr 17, 2011 | 08:42 PM
kennymo's Avatar
just run a new wire.
and it should NOT take an hour or 2 to do that. should take like 20 minutes.
Old Apr 18, 2011 | 01:10 AM
KPierson_'s Avatar
How much current does the heater pull? You might not have to go directly to the battery if the load is small. There are high current 12v constant feeds ran to the ignition switch and to the BCM. If the load is <5-10A I would consider grabbing it there instead of going to the battery.
Either way, make sure you fuse the wire as close as possible to the source. If you go to the battery make sure you go through an exiting grommet and then seal the hole back up.
Old Apr 18, 2011 | 01:24 AM
thescreensavers's Avatar
Mr.202?
rear window heater?
derres
Aug 28, 2015 03:27 PM
RA102223
Aug 15, 2015 09:24 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Karnicle
Jul 23, 2015 05:08 AM
