JDM Trim Modification For Navigation-Equipped Vehicles
Old Apr 13, 2013 | 06:21 AM
purp35's Avatar
and also what trim piece did you use to fix the gap on he DD?
Old Apr 13, 2013 | 09:39 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
You trim off about 1/8 of an inch, but as the first post says, unless you're getting a great deal on a used non-navi trim piece, buy the one that's the right size straight from Grubb's Infiniti, who, as far as I know, is still the only source in the US for the right part.
The gap between the radio and trim can be filled with any thin black plastic. The scosche trim piece I recommend is pretty much just a good quality part that can be cut and trimmed very easily with scissors and/or a razor to fit around various radios. If you want something cheap but not as easy to cut, just search amazon.com for some thin black ABS plastic.
Old Apr 14, 2013 | 11:50 PM
purp35's Avatar
thnx, ima finally pull the trigger and cut it tomorrow, i would of got the kit from Grubbs but i got a great deal for 200 flat at racingnissan for the dual air control and trim piece, it turns out that racingnissan.com is actually located at the nissan dealer next to my house which is literally 2 mins from my house so i couldnt pass that up.
Old Apr 15, 2013 | 02:10 AM
purp35's Avatar
idk if anyone is having this issue but im having trouble with my wiring, i got the new pioneer 8500 DD and im wiring it with the 70-7551, i was one of the lucky ones where my SQ didnt get effected how ever when i hooked up the AXXESS ASWC i got this really loud static coming from my woofer, im thinking it might be a bad ground. also i bought the micro brake bypass, its very simple to wire up but for some reason its not working properly, idk if its my radio or if its the car. so any advice would be very helpful on wiring the ASWC or the brake bypass
Old Apr 15, 2013 | 04:23 PM
No reason for the brake bypass on the 8500 unless you're trying to break the law by watching videos while the car is in motion. Remove it to eliminate it as a noise source. If it were a nav-equipped radio which you wanted to have your passenger enter destinations while driving, I can see justification for the bypass. Otherwise, it's a big no.
Is the ASWC functional? The ground quality is important with regards to it sending signals, so if it were poorly grounded, the steering wheel buttons would work extremely poorly.
Old Jun 29, 2013 | 02:17 PM
Osa713's Avatar
Cut my trim piece today, i will post pics later this evening, thanks for all of the usefull info in this thread!
Old Jun 30, 2013 | 11:09 PM
Osa713's Avatar
My cut was pretty straight until the far right end where it became uneven. If i could do it over i would have picked one side to start cutting from :-) Doesn't bother me enough to buy another one seeing how I got the JDM trim for free!
Old Jul 1, 2013 | 12:00 AM
Looks like it came out pretty good, glad the guide is still being useful.
You could probably even it out with a piece of 800 grit sandpaper taped to a flat surface and just slide the trim back and forth along it lengthwise.
Old Jul 1, 2013 | 09:57 PM
Osa713's Avatar
Thanks for the tip, it doesn't bother me enough though
Old Oct 4, 2013 | 06:11 PM
G'duprideR6's Avatar
I'm buying a used JDM DD dash kit. I have a 2005 Non-Navi, so if I get a version made for navi, is it possible it will not fit correctly?
Old Oct 14, 2013 | 01:29 AM
It will fit fine, you'll just have about an 1/8 inch gap at the top. Few people would probably know it's not supposed to be there.
Old Aug 30, 2014 | 11:59 PM
KysG35's Avatar
At the moment I'm the other way around, I have the non nav trim and can't decide if I wanna hack it up or wanna just go with metra...
Old Aug 31, 2014 | 12:13 AM
Mr. Brooks's Avatar
Question
why not sell the dash kit if you can't use it.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
BfloG35
Oct 16, 2015 05:22 PM
