looking for hot wire
Old Nov 21, 2004 | 03:34 PM
RedondoG's Avatar
I'm looking for a hot wire in the trunk, but one that's only on when the ignition switch is in the ON position (can not be on when the ignition switch is in the ACC or off position).
This wire will power a relay to turn on power (@ 20 amps) to a nitrous heater blanket.
Can any one help me with this?
Terry
Old Nov 21, 2004 | 03:40 PM
RedondoG's Avatar
Re: looking for hot wire
sorry, the car is a coupe with a Bose system if that helps.
Old Nov 22, 2004 | 04:55 PM
rcdash's Avatar
The DIY guide to install a new amp + eq (look for the thread in the DIY section) has the wiring for the amp, which you could leach off of.
However, that wire is probably around 12 gauge (???) and probably not suitable to run another 20 amps through it. Another run of 10 gauge wire directly from the battery may be advisable (probably do 4 or 6 gauge while you're at it for future power draws).
Old Nov 23, 2004 | 02:44 PM
pathfinder36's Avatar
Take your car to the local stereo shop. They should be able to find the correct wire to power up upon ignition. They had my stereo system wired that way initially, so I'm sure it can be done for your nitrous blanket.
Old Nov 23, 2004 | 02:45 PM
The other option would be to run from battery and put a on/off switch in your car.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
