Valentine one consealed installation w/ pics
Old Jan 25, 2012 | 11:45 PM
adymanis's Avatar
So I just purchased a 2008 G35xs sedan and I had no where to mount my concealed display from the V1, after some dremeling, soldering, and hot gluing I was able to finally mount it in the cup holder. Below are pictures of the installation. The reason I removed the entire shifter trim was because since the concealed display sticks out about a 1/8" past the ashtray the lid on the shift trim would not close. I learned this was because the inside of the lid was lined with some sort of rubber gasket, it seems to possibly be a fire proofing material. So I disassembled the entire shifter trim and removed the rubber piece which allow for extra room for the lid to close.
Then I took the concealed display apart exposing the guts, this made it about 90% thinner so it would allow me to fit it in the ashtray. Next I dremeled the lip of the display to allow it to fit evenly horizontally within the ash tray opening.
Once I had the fitment right I unsoldered the telephone jack from the board and re-soldered it using extension wires. This was done because the telephone plug is on the side of the display instead of the back, which is a dumb design IMO. You can see the result here: (I got a little messy with the hot glue to cover up the connection so wires don't cross)
I then attached a 8-inch telephone cord to the display and ran it through a hole i drilled in the ash tray. Once the cable was run through the ash tray I used the opening inside of the shifter trim to run the cable.
On the back of the shifter trim I ziptied a RJ-11 Coupler and connected the telephone cable that ran from the ashtray. This was done because if the shifter trim ever get removed again, you can simply disconnect the telephone cable that is run to the V1 hard-wire adapter in the fuse-box.
And here are the final results.....
Old Jan 25, 2012 | 11:57 PM
Gettinby's Avatar
Clean set up. I like it.
Old Jan 26, 2012 | 03:23 AM
djfarhan's Avatar
sick sick sick!
Old Jan 26, 2012 | 03:31 AM
HenryLee's Avatar
Looks great! But kinda like the v1 rear view mirror option better.
Old Jan 26, 2012 | 03:59 AM
Gettinby's Avatar
/\ Harvey has that mirror set-up and that is the way to go
Old Jan 26, 2012 | 09:32 AM
broke_as_ajoke's Avatar
nice work bro
Old Jan 26, 2012 | 01:25 PM
Beebo's Avatar
awesome
Old Jan 26, 2012 | 01:44 PM
GR6RR's Avatar
This is for the display... but where did you mount the sensors?
Old Jan 26, 2012 | 06:23 PM
adymanis's Avatar
I mounted the radar on the windshield, above and to the right of the mirror. This way the radar is well hidden, away from obstructing the windshield.
Old Jan 26, 2012 | 06:25 PM
adymanis's Avatar
Yeah, I really like the concealed display that is integrated into the mirror too. The only drawback is that you have to mount an additional mute button somewhere. By having the display in the ashtray the mute button is within easy reach from the shift ****.
Old Jul 5, 2013 | 10:58 AM
GgHrOeSyT's Avatar
well done... i chose the ash tray for my conceal install also .. it was a escort 9500 ci
i wanted to install it in the rear view mirror but didnt want to risk it
you were brave enough to take it all apart
Last edited by Wrathernaut; Jul 7, 2013 at 09:05 PM. Reason: Don't post-spam. Use a single post instead for a thought.
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
9tray turbo
Sep 29, 2015 10:22 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
