Pioneer AVH-P8400BH
#137
DWalt - It depends on what year your G is. Check out Wrathernaut's Double Din Shopping and Resource List
Lij1 - For this unit use the PAC-ROEM if you are intending to keep your factory Bose.
Dwalt024 (05-17-2012)
#141
Yep:
1) The first thing to do is read through Wrathernaut's Double Din Shopping and Resource List.
2) Then go to post #1 of this thread and check it out.
3) Next, post your questions or anything you're confused about right here.
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
#142
#143
#144
#145
so i jst installed this unit yesterday,.
wit rear view camera...
and using pac rom . steerin control
bose harness
jdm kit
video out put cable - ryb. for my andriod t.v out
and ipod cable
extra usb cable
for 03 -04 dont buy the scortch trim kit.. useless and doesnt fit
also if u wanna by pass ur gonna need a module
and to actaully enjoy all and full option must get the ipod / iphone cable 201s
GREAT GREAT BLUetooth phone calls. clear and shows all contacts and numbers
sound good also
clear and nice interface.
only thing im having trble wit is .. im not sure which format the double din can play thru usb
i wanna watch my videos/movies that are on my hard drive. but for some reason wont play
any1 know what format they have to be ?/
i tried h.264 n avi thanks
sounds awesome .. it improves the bose speakers.. krystal clear .. and equ. has allot of setup n featuere to control the sound
bose harness
jdm kit
and ipod cable
extra usb cable
sound good also
#147
#148
Just have a quick question when installing the back up cam on the 8400BH. I just bought a basic Koolertron License Plate Rear View Backup Camera from amazon to see how it worked. But there are 2 wires coming off of the license plate side of the unit, a positive and a negative wire. I do not know where to connect those two? I know the purple/white wire from the pioneer unit goes to the rear reverse light wire. But I was not sure where these 2 wires go?
Thanks for the help in advance.
#149
#150
Static p8400
teflon_don, did you end up getting rid of the static issue completely? and if so what ended up being the problem? my avh-p8400bh is doing the exact same thing (extremely bad on bass booster eq)
