Upgrade Rear Speakers or go with Amp/Sub
Old Aug 20, 2012 | 09:08 AM
neo2000x's Avatar
Hey guys, I have a 07 non-bose unit and I just upgrade the fronts/tweeters with Polk DB6501s. They sound great but they are more of a mid-high speaker and lack bass. I was thinking of upgrading the rears with coaxials but wasn't sure if that was going to give me the added bass I'm looking for, or am I better off going with an amp/sub set up? I know the sub is the ideal way to go but I'm looking on the easier install since I time is something I don't have a lot of.
Will upgraded rears be good enough?
Old Aug 20, 2012 | 11:38 AM
bkmitchy's Avatar
Amp/sub would be the setup for better bass. I had the same situation after upgrading only my front speakers at first. The stereo shop I used was able to add an amp and sub and then use the existing rear speakers for fill all in about an hour and a half on a busy Saturday. After this install, I actually had some real bass, not the artificially manipulated bass from the stock Bose amp.
Old Aug 20, 2012 | 03:15 PM
eggyhustles's Avatar
did u amp the polks
Old Aug 20, 2012 | 03:44 PM
neo2000x's Avatar
Didn't amp it up since the speakers seemed efficient enough to work with the stock HU. Do you recommend an amp?
Old Aug 20, 2012 | 04:00 PM
Yes
i would amp them first
that's why your midbass is non existant
Old Aug 20, 2012 | 05:14 PM
neo2000x's Avatar
Midbass is there, just less bass than the stock speakers and I think that's expected from components correct?
It looks like the stock non-bose head unit does not have a pre-amp out, so I'll have to tap with a LOC to one of the lines. I could do this with the rear door speakers, but I've read post recommending doing at the head unit. What's the diff? Is there filter of the signal by the time it gets to the rear speaker?
Old Aug 20, 2012 | 05:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by eggyhustles
Yes
^ This.
About 100w/channel will open up the bass a lot. If that's not enough for you, coaxials in the rear are NOT the way to go to get bass.
Old Aug 24, 2012 | 01:31 AM
BluIDvl's Avatar
Put a box in the trunk....one 10 or a 12 with an amp, you wont regret it!!!
jsimonk
Dec 22, 2023 03:49 PM
mjfenix
Aug 17, 2017 05:49 AM
Daniel k.
Nov 3, 2015 09:52 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
