I Need A Single DIN
Old Sep 13, 2012 | 12:46 PM
03XG35's Avatar
I Need A Single DIN
I need a single DIN. I don't want a double DIN because I have the problem where my car wont lock.
What kit do I need for the setup. I want a din it doesnt have to be expensive. As long as it will last.
Also, the reason why im doing this is because i have the curcuit problem where the radio never works, and the heat stays on. Will this fix that problem??
Thanks.
Old Sep 13, 2012 | 12:55 PM
Frankieg35's Avatar
EBay has the metra single din, they aren't bad for the money but the buttons look cheesey compared to the oem..
Old Sep 13, 2012 | 02:09 PM
prinny's Avatar
Rather just go for a double din IMO cause a single din doesn't look very nice. Getting any new head unit setup will fix that problem.
Old Sep 13, 2012 | 07:27 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Metra will be the easiest way to do a single-din, as they have the single-din option in their trim that comes with the little single-din cubby beneath the radio slot.
Yes, it will fix the a/c issue.
Old Sep 14, 2012 | 09:07 AM
RastaManMax's Avatar
Thanks.
Problem where the car won't lock.
Old Sep 14, 2012 | 10:14 AM
Yeah, fixing the car locking problem would probably be at the top of my list.
Old Sep 14, 2012 | 11:47 PM
03XG35's Avatar
Can I use this to fix my problem?Mine is a 2003. http://www.slidegood.com/make-model/...-assembly.html
Also, can somebody provide links to the metra kit?? And can I just go to a store and purchase a new kit and expect it to fix the problem. in other words does it come with the new circuit board to fix the ac problem
Old Sep 15, 2012 | 12:09 AM
If you want to replace your entire dash, it could work.
https://g35driver.com/forums/audio-v...urce-list.html
Yes, it will come with the circuit board.
Old Sep 15, 2012 | 12:27 AM
03XG35's Avatar
WWhat do you mean entire dash? Can I buy that radio, and still pay someone 50 bucks to install it and be good to go? If so ill order it now.
Or
Can you provide me a link so I can purchase the single din metro kit please. Im just gonna buy a cheap unit from walmart or something. Im justs sick of having to radio or heat/ac
Old Sep 15, 2012 | 01:49 AM
Or
No, the 05+ radios will not fit in your 03 dash. It will fit an 05+ dash. Unless you go through the complete changeover of dashboard of your car, it won't fit.
Metra Double/Single Din Kit 99-7604 sources: Amazon - (Black, Silver or Tan)
Old Sep 15, 2012 | 06:47 PM
prinny's Avatar
You're probably going to get charged a good amount more than $50 to have a shop do it. It takes awhile to do. Was a big pain in the add souldering all those wires together and getting the steering controls to work.
Old Sep 16, 2012 | 09:48 AM
My post above was incomplete. Explorer keeps freezing for G35driver.
The car not locking is probably related to a door actuator problem if by not locking you mean you can still lock it manually with the key (common problem with the G).
The heat staying on issue is also a common problem with the radio/AC controls and replacing the AC controls and radio will fix this issue. Look at Wrathernaught's sticky at the top of this subforum for everything you'll need to get the job done. It's a bit of a pain with this car but for sure doable. I never did anything electrical with any of my cars in the past and I got this working easily by doing my research and asking a few questions to fill in some newb gaps. As posted above, the install will be a lot more than $50 when you see the amount of paneling that has to be removed to get to the radio and all the other crap/custom work required to get it looking proper.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
BfloG35
Oct 16, 2015 05:22 PM
Learned Hand
Oct 1, 2015 09:02 AM
