sound deadening doors
hi everyone, im getting all my products together for my audio upgrade. my next purchase is gonna be sound deadening for the front doors. please give me suggestions such as brand, products, amount to purchase ect. also, any tips on install would be greatly appreciated. remember, im only doing the front doors at this time. thnx
I drove ttrank's car solo
I used Fat Mat in my install and it works great. I can't tell you how much was used, a friend of mine used some leftover from another build. For install get a small roller then use a hair dryer to heat up the material so it gets more pliable and roll it onto the surface. Make sure you cut out spaces for bolts and such so you can still get to them. Here's a pic for reference.
Show more
Show more
thnx for the replies guys. wrathernaut, what brand do you like? i know dynamat is the standard but i like to look at all options b4 jumping on something. Is this one of those things where even if you went with some cheap stuff, "something is better than nothing" or im i mistaken? as you suggested, im gonna throw the comps up front and forgo the sub for now if deadening gives me decent bass.
Dynamat's crap, which manages to survive because they have good marketing, so people know the name and think it's good (kinda like Bose audio). I highly recommend sounddeadenershowdown.com for deadening products. Other ones that good are ok are RAAMmat and Second Skin Damplifier.
Dynamat is great stuff, just severly over priced; like mentioned before they have amazing marketing. That said I used Fat Mat on my Tib I had years ago; 100 sqft for around $140 or so now last I searched, and it works perfect. I stripped the car down to nothing and did a single layer throughout the whole car, and then a double layer in the trunk area since it was a hatch back. I still had quite a bit left over. I had headers, with no Cat's and a cat back exhaust with no resonator; it droned bad at highway speeds. Needless to say after the fat mat install the drone was almost gone. It also kept in all the sound from my system; 2 JL 10w7's with a 1000/1 amp, and all Type R mids and highs front and rear powered by a 300/4. Outside of the car it sounded almost stock with just a little hint of the bass, but inside was .
I will give caution to anyone that uses the roller to apply any sound deadener to the inside of the outside sheet metal skins; you press to hard you will leave crease lines in the metal skin, trust me. The metal is very thin and easily can be manipulated.
You are definitely welcome; I had to learn that the hardway. I do know that most kits supply a plastic roller where as I had a wooden roller; that may be why I caused small creases/imprints from the roller going back and forth. You could only see them in the right light at the right angle, but they were still there none the less. I actually broke the plastic one, so that probably shows I was heavy handed anyways!
