How to Add Auxiliary or iPod Input to the Factory Radio
Old May 20, 2022 | 04:56 PM
  #331
05_SkylineSedan's Avatar
20 Year Member
Wrathernaut is the king of all knowledge on this subject so go with whatever he says! Good luck with the install.
Old May 20, 2022 | 06:29 PM
  #332
DLR06G35X's Avatar
Bose and Nav
Yeah I kind of figured out he is the go to on AV and stereo stuff as soon as I joined. Thanks, a stereo install place is doing it Monday morning, I just wanted to make sure that if I’m supplying the equipment it is compatible.
Old May 21, 2022 | 02:12 AM
  #333
DLR06G35X's Avatar
Bose and Nav
Called USASPEC and spoke with tech support specifically about compatibility of the BT45-NIS product compared to the BT45-INF. The tech said Infiniti and Nissan share the same harnesses and radios for the most part and both products would work. The BT45-NIS would be installed behind the radio and the BT45-INF would be installed to the SAT harness in the trunk. Really it comes down to a couple factors. 1) would you rather remove stereo or run wiring from trunk under the carpet. 2) availability and pricing(found the NIS set up for $167 delivered on Amazon compared to $225 for INF setup up from an online AV store that was sold out on Amazon). I have an install appointment for the NIS setup Monday at a local installer, I’ll advise.
Old May 23, 2022 | 01:48 PM
  #334
DLR06G35X's Avatar
Bose and Nav
BT45-NIS installed and working as advertised. It uses the CD button, preset #5 is wireless Bluetooth and preset #6 is AUX. then there is a charging only USB port. Purchased from Amazon for $167 delivered with Prime. It looks like the price went up a little but still good. Install should have been 1 hour but the installer said it took closer to 2 so $200.
Old Jul 24, 2023 | 11:56 PM
  #335
yhwhdesign's Avatar
stock - soon not to be
Tapping into sat m90 didn't work
Originally Posted by Wrathernaut
Because of the high failure rates of factory radios in our cars, I believe spending any money keeping the factory radio in our vehicles is poorly spent. However, some of them have been reliable and not everyone wants to replace them. So my opinions aside, I will still (as always) try and give out good information.
This post is still a work in progress, which will get refined over time and input from others. Links to installation guides for each adapter will be added as I find them.
All links are to Amazon when available, since pricing on them varies greatly, and this allows you to compare between multiple sellers quickly, see reviews or just see a photo or two of the product. There may be cheaper sources for one or two of these items, but this post is about information, not so I have a second job tracking down who has items in stock and at the best prices. Product model numbers are always provided so that you can research them to your heart's content.
There are three basic methods of adding an auxiliary input to the factory radio (plus, option B if you already have the factory satellite radio adapter).
Whether your factory radio is the Bose "Premium" audio system or the non-Bose "Base" system, the options are identical.
The first and second types - auxiliary adapters - are treated by the factory radio as a satellite radio adapter, and give quality as good as the factory satellite radio. The major difference between the first and second type are whether they connect at the back of the radio (Nissan-type) or at the satellite radio harness (Infiniti-type). Nissan-type require removal of the factory radio (video at the bottom of the first post).
The third type are wired FM modulators. These produce a much higher quality audio than wireless FM modulators, since they bypass the vehicle's antenna, their signal isn't subject to interference or the limited power of a tiny transmitter. Their quality is equal to the best FM radio reception you could possibly get, so depending on your audio source, you may not tell the difference between a wired FM modulator and an auxiliary input of the first or second type. They connect to the radio through the radio's antenna, and as such, require removal of the factory radio (video at the bottom of the first post).
Type #1 - Nissan-type adapters which connect to the back of the radio:
USA SPEC BT45-NIS
- Adds bluetooth calls and audio support
- Adds 3.5mm stereo auxiliary input
- USB charging port (not for music storage)
- Includes microphone for bluetooth calls
- Works with steering wheel controls
GROM BT3-NIS02
Write-up from djtalon's install- Steering wheel controls work with phone calls and Bluetooth streaming.
- There is no song information sent for Bluetooth audio.
- Seek up/down functionality reversed from the factory radio.
- Sound quality is comparable to that of MP3 CD.
GROM NIS02A1
Grom basic AUX-1 input. No control of anything but volume through the radio, but at about $70, it's a cheap way to get an analog signal into the factory radio.
Pacific Audio Corporation PAC ISNI531 -Provides you with two 3.5mm inputs.
Pacific Audio Corporation PAC ISNI571 -"iPod Kit" with a 30-pin iPod input and one 3.5m adapter - . An iPod connected to the ISNI571 can display the artist/song on the factory radio and you can browse by artist, album, genre and playlist from the factory radio's controls. It also keeps the iPod charged.
Enables All iPod Features and Functions from the iPod and the Radio – iPod Interface displays information and provides iPod control from both the iPod and the radio.
Audiovox (Dice) Mediabridge AMBR-1503-NIS -A little more expensive than the others, but it has available bluetooth for phone calls and streaming, USB, and iPod connections. iPod can be controlled similarly to the other adapters in this class.
GROM Audio GROM-AND-NIS02 - manufacturer's product pageNearly identical to the GROM-USB2-NIS02, but lists at about $25 cheaper, only differences appear to be that this unit does not support the GROM Bluetooth dongle for handsfree telephone and bluetooth streaming and it includes a micro-USB cable instead of a USB extension cable. Connects behind the factory radio, and provides both 3.5mm and USB interface. This device also allows for use of the steering wheel controls, and lists ID3 tag info on the radio display when using the USB input.
GROM Audio GROM-USB2-NIS02 - https://g35driver.com/forums/audio-v...x-install.htmlUSB, iPod, Android, Bluetooth (with purchase of additional adapter), AUX interface.
Connect, control, charge, iPod/iPhone and Android phone/tablet.
Aux input with 3.5mm cable or optional 3.5mm flush mount input.
USB supports any FAT16/32 stick/drive, plays MP3, M4A, OGG, FLAC, AAC, WAV music.
Bluetooth Streaming and Handsfree with optional accessory. Accept and reject calls from radio or steering wheel, make calls with voice dial, incoming call display on radio display.
Control from radio or steering wheel with track info and text on radio display.
Charge any other USB device with a charge cable from the USB port.
http://www.gromaudio.com/store/andro...interface.html
PAC AAI-NIS2 -Installation guide and reviews.
Discontinued, but still available. It was a pretty basic auxiliary input that required additional products to charge a connected iPod.
Type #2 - Infiniti-type adapters which connect to the satellite radio harness in the trunk:
USA SPEC BT45-INFI Bluetooth audio streaming, phone calls, and an AUX input. (same as BT45-NIS, but connects to the satellite harness in the trunk) Retains satellite radio. Video Demonstration.
Modified Factory iPod Integration -These were a Nissan iPod integration adapter which had been modified to work with the Infiniti harness in the trunk. Some of these still exist, and pop up in the private classifieds or eBay, but I can't find anyone who's still selling them new.
Type #3 - Wired FM Modulators: (also referred to as antenna-bypass)
All of these wired FM modulators requires both standard and reverse antenna adapters (Scosche NDAKB combo kit) to be installed on the factory radio.
Pacific Audio Corporation PAC IS77 -Charges iPod and provides an audio input from it, or provides a single 3.5mm aux input for use with any other audio device. There is no control over the iPod from the vehicle, all control is done through the iPod itself.
Pacific Audio Corporation PAC IS32 -Provides a charging-only USB port and a 3.5mm audio input.
Pacific Audio Corporation PAC ISFM21 -Provides a Bluetooth a2dp (bluetooth streaming audio) input. It does not support bluetooth phonecall support or any remote control ability.
Option B:
The factory service manual for the coupe lists pins 33, 34, 35, 36 on the satellite radio adapter harness for the audio signal, and pins 1,2,3,4 for the sedan. The charted numbers are different, but they refer to the same wires on either sedan/coupe harness. They are arranged in a 2x2 square on one side, so they should be easy enough to identify.
The wire colors at the satellite harness for 2003-2004 coupe and 2003-2006 sedan are:
Left+ RED
Left- GREEN
Right+ BLACK
Right- WHITE
The wire colors at the satellite adapter for 2005-2007 coupe are:
Left+ Blue/Green
Left- Blue/Yellow
Right+ Orange/Blue
Right- White/Blue
The wire colors at the M90 harness at the back of the factory radio are:
Left+ RED
Left- GREEN
Right+ BLACK
Right- WHITE
You can tap them at the back of the radio, or follow the wires from the satellite adapter in trunk to somewhere in the main cabin.
2005 infiniti g35x
Non nav
non bose
Has cd changer
No tape
Has satellite receiver in trunk.
I opted to hard wire a 3.5mm jack into the m90 plug off the back of the radio.
When I tested. I got nothing.
tried a different device and still nothing.
i plug in my device. I hit the radio button to cycle from fm1 to fm2 then it shows sr1 then sr2.
No audio at either sr1 or sr2
It just shows radio id.... and some other number.
Any ideas?
Old Dec 26, 2023 | 04:02 AM
  #336
juliustome's Avatar
2006 g35x sedan
Current Cheap aux solutions for 06 Bose g35 sedan
Hi I’m new to this forum and after looking at the solutions provided a lot of them are discontinued and really hard to find. I’m looking for a current solution for cheap aux that would also be available in Canada. Thanks
Homerbalooza
Sep 8, 2011 10:47 AM
AlabamaG35
Feb 15, 2011 01:33 PM
bsowhat1
Archived Sales
Mar 21, 2010 12:08 AM
c900t16
Mar 13, 2010 10:24 AM
06g35meister
Sep 30, 2008 06:16 PM
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
