Subs Cut Out & High Pitched Noise..
Turn the infrasonic filter to on, and the freq setting for it to 25hz, the 10w0v3 doesn't go below that.
Can't tell if the input sensitivity (gain) is at max or like 30%, but if it's at max, lower it to get rid of the whine, if it's only at about 30% already, your ground may be bad, or there's a input level mismatch - Where do the RCAs go to in the stock wiring? Can you get a photo of that? If they're going into the post-amp wiring, the amp is configured wrong.
It really is a lot of things that could be wrong, so you're probably best taking back to the shop, hopefully there's a tech there who knows how to do it right.
I just dropped it off, they said it was a bad amp or bad subs but theyll take a look at it. I hope they do and dont just say they did. I brought up a bad ground and he said it probably isnt. He also mentioned it might not be getting enough power. He said that amp should be wired by itself and not thru a dual amp kit. Im using a jl dual amp kit 4g to power both.
its a JL 300/2 and a 500/1 with a 4guage the 300/2 is powering a set of components in the front stage, and the 500.1 is powering 2 10in subs (300watts)
magnetism80
02-01-2019 10:00 AM
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
