App Radio Help
Old Mar 2, 2014 | 08:22 PM
clamchauda's Avatar
App Radio Help
Hello All,
I'm installing my AppRadio3 and am having an issue with the system install... I wired up the harness to the ROEM-NIS2, but when I plug in the unit it returns no power at all. I checked the connections for switched power, constant power, and ground and they are all good. Based on this, I believe I should be getting power to the unit but I feel like I'm probably missing something really simple. HELP!
TYIA
Old Mar 2, 2014 | 09:05 PM
Urbanengineer's Avatar
Make sure the unit is working fine by getting it tested. Are you following Wrathernaut's double DDin install guide?
Old Mar 2, 2014 | 09:09 PM
clamchauda's Avatar
Yeah I followed Wrathernaut's wiring diagram to a T... at this point I can only imagine that it's the unit unless it's something stupid like there's a switch on the AppRadio that I didn't flip or something.
Old Mar 2, 2014 | 10:16 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Did you not disconnect the battery before starting work and blow the fuse? Does the AppRadio have a fuse on the back that's blown?
Old Mar 2, 2014 | 11:58 PM
clamchauda's Avatar
Fuse is still good...
Old Mar 3, 2014 | 12:35 AM
Pic of the current spider wiring mess? I am imagining you are having an issue with your switched power if it won't even turn on!
Old Mar 3, 2014 | 12:38 AM
clamchauda's Avatar
I can put a picture up but I used a volt meter to check all the connections and they're all connected and good.
Old Mar 3, 2014 | 09:44 AM
clamchauda's Avatar
Here's the rat's nest...
Attached Thumbnails App Radio Help-img_20140303_061857.jpg   App Radio Help-img_20140303_061902.jpg
Old Mar 3, 2014 | 11:32 AM
Well the cardinal rule is never to crimp but to t-tap. I'm going to go ahead and say redo that crimp and you'll be amazed how you missed the copper.
Old Mar 3, 2014 | 11:43 AM
clamchauda's Avatar
Would I need to recrimp if the volt meter is reading a connection on the main 3 wires?
Old Mar 3, 2014 | 12:06 PM
I don't know about what clergy use for connecting wires, but the best method by far is solder, preferably heat-shrinked.
T-taps have their place, like if you're just trying to add something temporary, or there's not enough play in the wires to solder in a proper connection, but I'd never use them as a primary connection method.
Old Mar 3, 2014 | 11:33 PM
clamchauda's Avatar
Regrounded it and it works now!
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Learned Hand
Oct 1, 2015 09:02 AM
Siciliang35
Sep 18, 2015 11:22 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
SIKKI
Picture Share
Sep 15, 2015 10:23 AM
