Mechanically sound Electronically downed
Old Dec 24, 2014 | 09:24 PM
jstratt's Avatar
I Have a 2006 G35 coupe with under 54K miles. I got it in 2011 and only put about 2k on it due to titling issues. so the car has sat for a while. recently I found the battery drained and it would not jump or hold charge. the battery was barely a year old. so I got a new battery replaced it and started the car to ensure it would run. the following morning that battery was dead. I jumped it and it and the engine died as soon as the cables were removed. so today I replaced the alternator. it runs well now however there are some major problems. the brights don't work, seat heaters don't work, heater/ac doesn't work and the speakers do not work, though the head unit does. help please
Old Dec 24, 2014 | 09:32 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
If you don't have the knowledge or equipment to trace the drain directly, pull fuses for all the accessories and see if it is still draining overnight. If it holds a charge with the accessories fuses pulled, start adding them back in to determine what's draining.
The factory radio & amp are both known causes for drain when they're failing, so you might want to start looking there.
This might help: https://g35driver.com/forums/audio-v...-now-what.html
Old Dec 25, 2014 | 08:46 PM
jstratt's Avatar
Speedometer and odometer stopped working 2006g35
i looked at all my fuses can someone point me in the right direction? I have several problems with my 2006g35 coupe speedometer odometer seat warmers high beams vdc stays off. Jut replaced battery and new alternator. 53k on car.
Old Dec 26, 2014 | 08:20 PM
This part of the forums is for the audio/video electronics, not general tech troubleshooting. You might want to hit up this one first - https://g35driver.com/forums/general...questions-189/
chinee
Jun 10, 2024 07:48 PM
snic09
Nov 8, 2017 01:46 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
itschuckster
Jul 25, 2015 08:07 AM
