A must do mod for those that are keeping the stock deck
Old Feb 21, 2005 | 11:02 PM
g35john's Avatar
Today I hooked up an Alpine Pxa-h510 surround sound decoder. This is a must do mod for those that want aftermarket sound while still keeping the stock deck. The unit also has an 11 band parametric eq, DSP, and digital time alignment. The system sounds great. I highly recommend this unit. Its cake to hook up as well.
Old Feb 21, 2005 | 11:32 PM
shooter's Avatar
It's not the critic......
How much? Where did you buy it? Any Install pics? Thanks!
Old Feb 22, 2005 | 12:07 AM
blksnake's Avatar
Here is a eBay link: http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Looks promising. How did you hook it up?
Old Feb 22, 2005 | 08:35 AM
CLS2G35's Avatar
Cool unit, but overkill if you're just doing audio. Although the time alignment is pretty sweet. Not sure how Alpine does their time alignment, but time alignment features usually only work if you're bi-amping your component set, I think.
Old Feb 22, 2005 | 09:58 AM
g35john's Avatar
The time alignmet works perfectly, I have one 4 channel amp for my door speakers, and a mono sub amp. I got the unit on Ebay for $102. Ill see if I can get some picts of my install. Its very easy to hook up. Just connect the power,ground and remot wires and run your RCA's (from a LOC) into the unit, the out to your amps. There is a desplay screen that you can mount anywhere you choose. I mounted mine in the sunglass holder. Works and looks great. And when not being adjusted I just close the holder and you cant tell its there. The EQ allows my to tailor the sound perfectly (for my needs) and even has presets to save your settings. I really wanted a unit with DSP also. Now I have it and my sound is as good as most aftermarket systems I have heard. No DD for me. I will be getting one of those digitalwheelz screens thoughf for my nav system. By the way, you do not need to Bi-amp the components to take advantage of the time alignment feature.
Old Feb 22, 2005 | 03:10 PM
blksnake's Avatar
Sounds good. Look forward to seeing the photos.
Old Feb 22, 2005 | 03:38 PM
g35john's Avatar
Will do, give me some time.
Old Feb 23, 2005 | 11:46 AM
djrobx's Avatar
Looks very nice. Can the processing features be used while retaining simple stereo behavior? I don't want Dolby Surround processing on my music, and I want my rear speakers playing music.
Old Feb 26, 2005 | 07:47 PM
g35john's Avatar
I have taken the pictures I promised earlier. I don't know how to upload a picture on here so just give me your e-mail address and ill send them out to you.
Old Feb 26, 2005 | 08:25 PM
SI_G35Coupe's Avatar
if you want, you can shoot me the pic in an email and i will host it up for you
steve @ sig35coupe.com
Old Feb 27, 2005 | 03:52 PM
g35john's Avatar
Click on the link below to see the pictures of the surround install.
http://www.hillyhead.com/g35/
Old Feb 27, 2005 | 05:59 PM
kornstar369's Avatar
veRRy nice....alpine makes the ultimate best in head units. biggest bang for your buck for sure. and thats not overkill, if youre like me , audio in your ride is a must. nice clear clean crisp audio....it really is music to my ears.
Old Feb 27, 2005 | 09:42 PM
g35john's Avatar
I agree 100%. Must have audio. This alpine unit does the trick. The eq does great things to sound quality in my G. I like the DSP features too. For around $100, the bang for the buck winner in my book so far.
Old Feb 27, 2005 | 11:14 PM
sushmaster_g35's Avatar
what i want to know is exactly what is this and what does it do? how does it help and is the installation hard? and also would it void any speaker warranties?? would help a lot! becuase i really want that clearer sound but dont want to replace deck or speakers...thanks!
Old Feb 28, 2005 | 10:58 AM
g35john's Avatar
The unit constists of two parts, the display(in my sunglass holder) and the brian (installed in my trunk). You will have to use aftermarket amps with this unit. If you have the bose unpulg the harness from the amp and find all the wires for the remote turn on, and and all the speaker in and outputs. Install your amps just as you normally would. You will have to use a LOC as well to convert your front speakers signal to RCA. The brain unit only has 1 set of RCA inputs and 3 Pairs out. So, just connect the input, and then run each of the RCA outputs to thier respective amplifier. There is also a small wiring harness that contains a remote wire, a power wire and a ground. Hook all that up and its happy days. I already had my amps installed prior to the DSP so I just had to connect the power and stuff and run new RCA's. Install took me about 45 minutes. Less if you dont put it where I did.
