caution reverse message won't go away
I tapped in the reverse wire at the tail lights. Camera goes on in reverse and off in gear but theres a caution message that stays on no matter what i do unless i shut the camera from the pioneer hu. I tried changing polarity, i tried unplugging the hu and reset it. Same thing.
The message stays on when the camera shuts off. I know i tapped in the reverse wire. And its grounded. I can't figure out why this is .
This message is always on . No matter if i watch a dvd or listen to the radio or aux. Its dont go off unless i shut the camera from the head unit. No matter if thr parking brake is on or off, lights on or off. I don't get whats triggers it
Where did u pick up the reverse feed? I cut into the wire straight at the tail light.
Mine isn't installed in my G but essentially the same for my tiguan and mustang and the G would be the similar.
My camera is actually powered all the time. So power and ground terminates at the head unit(I'm using the accessory wire to power the camera as well). In the mustang, I had to run a wire from the head unit back to the taillights and use the reverse light bulb as a trigger. In the tiguan, it uses canbus so the metra harness had a reverse trigger wire and I just had to connect that to my reverse gear wire on the head unit.
The same camera on the same head unit.
Stevoe
11
Apr 19, 2020 03:11 PM
infinitigman35
Dec 29, 2017 05:19 AM
IllaNoizeTV
May 19, 2016 01:53 PM
