Where is the SAT unit?
Old Mar 2, 2005 | 01:08 AM
Corinth's Avatar
My 03.5s G is pre-wired for SAT and I have the opportunity to get the SAT receiver from my buddy's 04s G. Can anyone tell me where it is, how to get it out, and if I will need any tools. The antenae will not be removed just the SAT receiver unit.
-Can I just unplug it once I find it?
-Will my buddy start experiencing any wierd side effects besides not having SAT?
Thanks.
Old Mar 2, 2005 | 07:42 AM
Benzito's Avatar
Do you have a coupe or sedan?
Old Mar 2, 2005 | 08:07 AM
Noremac's Avatar
In the sedan, the Sat unit is located just behind the passenger-side rear seat. You will need to remove the trunk lining under the parcel shelf and behind the rear seat. The unit is normally attached with three screws and double stick tape - which can be a b*tch to remove. The harness connector and antenna connector are easy to remove. See this post for some pics: https://g35driver.com/forums/audio-video-electronics/41864-replacement-xm-sat-receiver-pics.html
Old Mar 2, 2005 | 12:29 PM
DiamondGCoupe's Avatar
What about for the coupe?
Old Mar 2, 2005 | 01:15 PM
g4s's Avatar
g4s
should be where the bose amp is located. to the left of the spare tire.
Old Mar 2, 2005 | 04:04 PM
Corinth's Avatar
Originally Posted by Noremac
In the sedan, the Sat unit is located just behind the passenger-side rear seat. You will need to remove the trunk lining under the parcel shelf and behind the rear seat. The unit is normally attached with three screws and double stick tape - which can be a b*tch to remove. The harness connector and antenna connector are easy to remove. See this post for some pics: https://g35driver.com/forums/showthread.php?t=41864
Exactly what I was looking for. I remember that thread but I couldn't find it. Thanks for the link and info.
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
