6 disc cd player in trunk
Old Aug 19, 2017 | 01:33 PM
G35dennis's Avatar
'07 Infiniti G35 has the cd player in the trunk it will only play any disc for about 45 seconds then just stops. Tried a cleaner disc it only played it the same. Any other ideas?
Old Aug 19, 2017 | 01:42 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Switch to mp3's
J/K, the component is probably failing due to age, if you have access to an IR scan gun shoot the lid and check temperature on the surface of the changer when it fails vs. the temperature when it's working properly. Also make sure the trunk partition dividers are properly installed and the exhaust air flap doesn't have anything blocking it (back corners of the trunk near the bumper area, looks like a little flap that goes outside the car). Air needs to be flowing freely through that part of the trunk to keep stuff from overheating but the component is a decade old and is probably just going through a natural death cycle.
Sedanman07
Nov 7, 2006 09:54 PM
Railgunner
Oct 28, 2006 12:41 AM
Cooldmitriy
Aug 5, 2005 08:53 AM
tbbucs92
Mar 4, 2005 03:05 PM
KjbAlto
May 7, 2004 03:35 PM
