help removing sat antenna!
Old Apr 13, 2005 | 06:20 PM
cloudy6MT's Avatar
Tried pulling the factory sirius antenna off the roof. That thing is stuck on real tight! And I don't want to damage my car, anybody who's done this have any hints?
Old Apr 13, 2005 | 07:09 PM
GRider35c's Avatar
a friend took his off and left a huge dimple in the trunk...
take it to the dealer yo
Old Apr 13, 2005 | 07:30 PM
QBall's Avatar
I wanted to have mine moved from the roof to the inside but I've been worried about if it would be noticeable
Old Apr 13, 2005 | 08:34 PM
cloudy6MT's Avatar
Alright guys, I just did it. Use floss to cut through the adhesive and it comes loose. Be careful not to move it around too much, there are magnets on the bottom too. Thanks for all your help!
Old Apr 13, 2005 | 08:38 PM
GRider35c's Avatar
nice work man! phew........
Old Apr 13, 2005 | 08:49 PM
QBall's Avatar
is the trunk mounted one or the roof? I think the roof one has a little notch for the wires to pass through into the car, I'm assuming that would have to be sealed up.
Old Apr 14, 2005 | 12:43 AM
Gee Im Fast's Avatar
So wait...use floss and thats it??? There is no hole in the roof??? Do you have pictures of the aftermath? I am curious because I want to do it too, but don't want a hole in my roof...Thanks!
Old Apr 14, 2005 | 03:31 AM
GRider35c's Avatar
no azizam its held on by magnets...
Old Apr 14, 2005 | 08:56 AM
Beowulf's Avatar
Those don't work that great inside... Inside anntenas don't work well outside of urban areas that don't have the ground boosters... I would personally just paint it and get used to it. You could damage the roof and get really bad reception after all that work removing it. Also if you don't have one of the newer "mini" anntenas you could try that also.
Old Apr 16, 2005 | 07:02 PM
paintedantenna's Avatar
If you like the idea of getting it painted
Try our site www.colormatchantenna.com if you want it painted. We just can't paint the ones that are made of rubber, just the hard plastic antennas.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
dcsbh1
Oct 1, 2015 03:15 PM
