Door Speaker Enclosure Prototype
Guest
Posts: n/a
Hey Shooter - I bit the bullet and decided to start out on my bose stereo upgrade - I am going to start with 6.5" MB Quarts in the front...more later.
If you wanted to get measurements from the Sedan front for your 3d project, I'll let you know when I am doing the install and you can drop by - a little self-interest here
hopefully there is more room in the sedan between the window and the door panel so a larger enclosure can be made that will fit through the speaker hole in the door panel....the biggest enclosure i could make for the coupe was not big enough to do any good (it fit through the speaker opening).........i am trying to come up with a 2 piece enclosure, 1 part will fit through the speaker hole in the door panel and attach to the second (larger) part that will be installed from the back side (the access panel will have to be removed for this design.........gonna take a while to design and build a prototype tho....still modding the engine for now
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
FS[SoCal]: D/S 4080 Enclosure & JL Audio W6v2 10 inch
MrIP35
Nov 8, 2015 10:47 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
3d, 65, door, enclosure, enclosures, guards, indoor, inside, isothermal, mdf, printed, prototyping, putting, speaker, splash
