Anyone make a successful backup of NAV DVD?
Old Jun 15, 2006 | 04:05 AM
  #106
ccharlton's Avatar
Originally Posted by Alan
ah i see thanks. what is the difference between 6.3 disc firmware and 6.4 disc firmware? does 6.4 firm look better?
No much really. As for looking better... 6.4 Firmware will not change the appearance of your NAV, everything looks the same, just updated maps and POI's.
Old Jun 15, 2006 | 05:49 AM
  #107
jeremyp111's Avatar
I upgraded to V6.4 right away so I didn't have much experience with the previous version. Maybe someone else can help here.
Old Jun 17, 2006 | 03:40 PM
  #108
Alan's Avatar
so what does the 6.4 map cd change, and what does the 6.4 firmware change? does the cd update the streets and firmware update poi?
Old Jun 23, 2006 | 02:25 PM
  #109
Bronco991's Avatar
So is anyone willing to sell a copy of the newest verson of the zenrin cd? I have the firmware because my mom has an FX and she has the disc? Please let me know
Old Jun 28, 2006 | 06:10 PM
  #110
Bronco991's Avatar
I just got the Copy of the Navi DVD from JeremyP11. I put in the firmware, and it goes through, then it shows this screen and I put in the Navi DVD and it doesnt do anything and just stays on this screen, anyone have this problem and know what to do?
Attached Thumbnails Anyone make a successful backup of NAV DVD?-photo-35.jpg
Old Jun 28, 2006 | 07:05 PM
  #111
Derzigster's Avatar
turn it off and then back on (reboot it) and put in the DVD.
Old Jun 28, 2006 | 07:52 PM
  #112
ccharlton's Avatar
Firmware CD update the firmware so it is compatible with 6.4 and the DVD that you have in your NAV system has updated POI's and streets, etc.
Old Oct 9, 2011 | 10:11 AM
  #113
shahzad.shakir's Avatar
I used CloneCD and it worked perfectly with the 6.9. I backed up my own original, and my back up booted fine. Will try it out for a few days and see how it holds.
Note: I've done the 6.4 firmware update in the past, and I'm not sure if that is required for 6.9.
Worked in a 2004 G35 Coupe.
Originally Posted by animalz
Great news. I've successfully copied my own verson of Navi v6.1 dvd. I've been driving around with a copy in my navigation for 2 days and it works just as the original dvd which somehow got a few scratches on. I was a bit upset about damaging or loosing it, and always wanted to keep my original disk stored at home.... so here we go...
Some info: the original DVD is a Dual Layer disk, with over 8.1gb of data
Software that will NOT properly copy the navi dvd: Nero, Roxio Easy Cd Creator, Sonic junk, Alcohol 120% (My appologies fo suggesting it before, it actually refuses to burn due to size of the blank dvd)
Software that works: UltraISO, CloneCD, i used a 21 day trial...
Dual Layer Media: Verbatim DL DVD Disks @$16/3pk Buy.com
Drive used: NEC 3520A, latest firmware
I used a UltraISO to make image of the DVD first, for safekeeping and whatnot, i tried a bunch of image options: ISO, Nero, CloneCD, and the CloneCD image is the one I burned using Clone CD software... If you want to make a few $6 coasters you may try to use clonecd straigh, but who wants to do that.... anyway it took about 40 min to rip dvd, and then i burned it using CloneCD at 2.4x as a safety precaution, as my crappy dell has problem burning disks at high speed, due to slow hdd.
I hope this will put an end to this discussion.
P.S. Don't copy that floppy! err DVD!
Danielek
Aug 11, 2015 09:33 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
Rokafor
Jul 29, 2015 11:50 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
