JL 500/1 Amp TOO POWERFUL for JL10"w6?
Old Sep 29, 2005 | 05:38 PM
ZwerRacing's Avatar
What is a good amp for two JL10w6s?
Old Sep 29, 2005 | 06:20 PM
mr_ecktid's Avatar
Update...sigh, now my sub isn't even hitting anymore. I'm heading back to the place tomorrow to see what's up. Stupid installers.
Old Sep 29, 2005 | 06:53 PM
waijai's Avatar
i.love.gold
Where did you get it installed at?
Old Sep 29, 2005 | 07:25 PM
MikeyMike's Avatar
Rollin On Dubz
I dunno..I used to have my 500/1 hooked up to a 12w6v2..and I blew it...maybe it just wasn't set up right?
MikeyMike's Avatar
Rollin On Dubz
Oops
I'm sorry, I meant 10w6v2
Old Sep 29, 2005 | 07:51 PM
mr_ecktid's Avatar
Mikey: How did you blow it?
Moog, I got mine installed at Audiovision in Mesquite. I'm going back tomorrow to get it fixed, if they can't get it right, did you mention that you knew some friends that knew how to fix it?
Old Sep 29, 2005 | 07:55 PM
4080's Avatar
Originally Posted by mr_ecktid
How should I set the gains and eq's? Is there any way I can pop my sub or mess it up as it stands? I have no idea what the installer was smoking when he was telling me that.
Btw, I have 4080's custom fiberglass box. The installer said it doesn't hit as hard because there isn't a lot of air space in the corner...
-Mark
The 10W6V2 only requires .6 cuft. in a sealed enclosure per the manufacture of the speaker, JL Audio. My enclosure has .85 cuft. of internal air space. The sub takes up approx. .2 cuft., that would net .65 cuft of air space that the woofer is "seeing." The installer needs to find something else to blame, like his intallation/tuning ability.
4080
Old Sep 29, 2005 | 07:59 PM
MikeyMike's Avatar
Rollin On Dubz
Mr. Eck.
I blew it cuz I had a bass fetish at the time...just blasted it all the way for a couple mins and BOOM. Not to mention I had a "friend" set up the AMP, not a professional installer.
Old Sep 29, 2005 | 10:18 PM
g35audioman's Avatar
with the jl 500/1, or any amp for that matter, you need to be careful in setting your gains. With a 10w6, the RMS is about 250 watts i believe. With the 10w6v2, the RMS is about 400 watts. In the correct enclosure, such as the 4080 box, you shouldnt have any problem with the JL 500/1. However, as others have stated, if the gains are not set properly, you will definitely blow your subs.
FYI, I am currently running a pair of OZ audio matrix elite subs that are rated at 500 watts rms. However, i am currently running an amp that is capable of 1500 watts rms to the pair. My gains are set to account for that slight variation in RMS ratings between the subs and the amp.
Old Sep 30, 2005 | 12:25 AM
mr_ecktid's Avatar
ok the sub is back up and running, is there any dummies guide for setting the gains? Or is it basically how much bass I want to put out and at what risk? As of right now I don't know what the settings of the gain are like, I'm not sure if the installer has messed with it or not. This is a 10w6v2 sub in the 4080box btw for clarification.
Old Sep 30, 2005 | 01:13 AM
el_duderino's Avatar
JL has a gain setting tutorial on their website.
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
vamarris
Sep 26, 2015 12:56 PM
