What is the best 12in sub I can get for under $200(ebay or otherwise)????
Old Oct 27, 2005 | 01:16 PM
ScapGF's Avatar
Any input would be great. This would be powered by bridging 2 channels of a 4-channel 600w amp.
Old Oct 27, 2005 | 02:47 PM
G35blk's Avatar
alpine type-X. they hit hard! i think its like 1000+watt though o_O
Old Oct 27, 2005 | 03:40 PM
showtime240's Avatar
I had the pioneer premier 12" sub in my car...that was awesome....
They have a new premier series spl sub out....I think I am going to get that.
Like $130 for a 12"
Old Oct 27, 2005 | 09:32 PM
AVJunkie's Avatar
Kind of depends on what you're looking for. If you want something with great SQ and not just boom, check out the Image Dynamics IDQ12.
Old Oct 27, 2005 | 10:05 PM
GTF Unlimited's Avatar
for that price range. i'd recommend the alpine type r.
i'm a high end audio guy and when my friend pulled up with his new type r, i was pleasantly surprised. for a sub he got for 150 it sure sounded almost as good as my idmax. it does sound a little sloppy on the really low end but other than that, it's a great sub for it's price
Old Oct 28, 2005 | 12:12 AM
BlazeMaster's Avatar
I'm surprised that no one recommended a JL made sub. How do they compared to the one mentioned above?
Old Oct 28, 2005 | 12:43 AM
anish3232's Avatar
Id go with type R, I got mine about a month ago love it. I got it from ikesound.com for around 120ish shipped for the dual 2 ohm. Cheapest place I think on the internet really close to eBay price. The JL W3 is almost doulbe the price of a Type R, dont really think its worth it then, and the Alpine Type R has a bigger magnet and can take up to 1500 watts peak.
Old Oct 28, 2005 | 01:11 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
He stated he wanted something for less than $200 bucks, if you can find a JL sub that can beat out a type-r for less than $200 let me know.
Old Oct 28, 2005 | 01:45 AM
shortchaz's Avatar
Digital Designs DD2012a, marked at $169 right now and you order directly from the factory, may actually be cheaper than on the site, just have to call. I had 2 in my last car with 1000watts total to them in a ported box.
http://www.ddaudio.com/dd/caraudio/w...p?series=2000a
Old Oct 28, 2005 | 02:04 AM
you know honestly it depends on whether you want something with a lot of bump or something that hits nice and clean. i mean you could probably get a cheap sub with 1000wrms handling capability but you would seriously lack in sound quality. if you're willing to shell out $50-75 more i'd reall recommend that you just get an IDMAX
Old Oct 28, 2005 | 05:17 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Check ebay for a 12W3v2 and use it in a sealed enclosure. Nothing will touch this sub in the sub $200 price range. Just make sure u get the proper enclosure size and use the recommend wattage.
http://mobile.jlaudio.com/products_s...p?series_id=12
Wattage chart:
Old Oct 28, 2005 | 08:55 PM
ScapGF's Avatar
Thanks for all of the replies. Looks like I might go with the Jlw3
Now, What is the difference between 2ohm and 4ohm? Or does it matter which one I get.
Also, I value sound quality over Boom.
Old Oct 28, 2005 | 10:05 PM
conesweeper's Avatar
I love my Image Dynamics IDQ12
Old Oct 28, 2005 | 11:56 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Do you know what amp u are using?
You normally wouldnt run a 4-channel into a single sub.
You should either bridge a 2-channel amp, or use a mono amp.
If you are running one sub you want to present a 4ohm load.
Again, if you value sound quality, make sure u use a sealed enclosure.
Old Oct 29, 2005 | 09:55 AM
AVJunkie's Avatar
If you want SQ then go with the IDQ12 like I suggested earlier. You won't find a better SQ sub for the price.
