question about satellite radio
#31
#32
Originally Posted by jrc
I see it there for $260??? If I can get OEM satellite for sub $200, I'll cancel my PXNI order that I was planning to use with my non-factory XM receiver (a MyFi).
https://g35driver.com/forums/exterior-vendor/79058-satellite-radio-special.html
Excellent price!!
Albert
#33
Originally Posted by akrus
Take a look at this thread for the deal:
https://g35driver.com/forums/showthread.php?t=79058
Excellent price!!
Albert
Excellent price!!
Albert
Thanks for the info
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
#34
#35
Originally Posted by G35MoneyPit
Meeno24 and anyone else that has done the rear shelf antenna install - how has the reception been with this method? Any issues with the radio losing signal from time to time since it is not mounted on the roof or trunk? Thanks!
My antenna is on the rear decklid, inside my car. I haven't mounted it permanently (it's just sitting behind the passenger side head rest, on the carpet material) as I was concerned about reception. I am planning to mount it there as it's been working fine. On my commute, I have one area that causes a drop out of about 2 seconds, but other than that, it's not an issue for me.
One other thing I should mention is that I don't have tint. I'm not sure if that would make a difference or not, but I would test mount until certain, especially if it's a metallic based tint.
Albert
#36
If you have metallic tint on your rear window it can be a problem other than it’s the best install IMO.
#37
Thanks for the input, guys. I definately want to try the rear shelf install first and try and avoid the appearance of the antenna outside the car. I do have tint but I don't think it is metallic, so hopefully this won't be a problem. I'll also try mounting the antenna to a piect of sheet metal. Did you just buy some at the hardware store, shape it to the antenna base then glue them together?
#38
#39
#41
Yeah, it's cool for the most part. I get some areas down here where the thick palm trees will block the signal for a minute or two. I thought it might be the install location, but was riding in a friend's Magnum and he hit head spots pretty much the same places I did. I also have tint (20%) on the rear window. Basically, I doubt there's any difference between the rear deck and the roof.
#44
