Speaker Spacers
Old Dec 22, 2005 | 07:06 PM
mrdigital's Avatar
Speaker Spacers
A little while back I asked if anyone was able to make me spacers after attempting to make them myself (didn't have the right equipment) I deceided to do a search on ebay and found some. They are made by Mike of ZEnclosures (mlg9770 on here I believe) They're custom made for the Z, but they actually fit the G becaue the bolt patterns are a perfect match. With the Z, the sharpest angle of the spacer has to be at the bottom, but with the G, it has to be at the top.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
I'm using speaker baffles from Crutchfield with my install. So if anyone wants/needs spacers and is not able to make them, follow the link.
Old Dec 22, 2005 | 08:10 PM
el_duderino's Avatar
Still won't seal up against the back of the door panel...
Old Dec 22, 2005 | 09:02 PM
ben_there's Avatar
Making a seal?
I have read some other threads where you mentioned this before. Would weather stripping along the top of the bracket solve the problem?
Old Dec 22, 2005 | 09:26 PM
Depends on the thickness...
Old Dec 23, 2005 | 07:27 AM
mrdigital's Avatar
I think they did because the back of the door panel is flat. I will have to double-check. But they work for me, so i'm cool.
Old Dec 23, 2005 | 10:21 PM
bluerex's Avatar
Does anyone know if these will fit the rear?
Old Dec 23, 2005 | 11:19 PM
shooter's Avatar
It's not the critic......
no, they will not fit either of the rear speakers........
back seat speakers - there is not enough room between the oem speaker mounting bracket and the panels
rear deak speaker - 6x9's
Old Dec 24, 2005 | 12:08 AM
bluerex's Avatar
So then if you can't make an adapter, how should they be installed?
Old Dec 25, 2005 | 04:33 AM
bkchang79's Avatar
You can use molding clay (any arts and crafts store has it) between the door and baffle as well as the speaker to the baffle.
Old Dec 26, 2005 | 12:30 AM
Pearl05G's Avatar
Ill still to cutting circles and making my own new holes to mount the rings. A router table can really be your friend.
Although cutting these is quite simple with just a jig saw. No need for any special equiptment.
As far as gapping, I usually have a substantial amount of dampning on my/customers doors where it does seal up quite well. All though 3M strip caulk can do the job as well.
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
