Help with lights?
Old Jan 4, 2006 | 07:18 PM
futbol333's Avatar
Help with lights?
I have been installing a double din tv/dvd/etc. in my G35 coupe and for some reason at some point the lights on the interior stopped working. I checked all my fuses and none of them are broken currents. Here is a list of lights that dont work:
reading lights
light ring around key hole
door lights
Any ideas. Please help. Thank you in advance.
-Cameron
Old Jan 4, 2006 | 11:49 PM
KPierson's Avatar
Recheck your fuses. There is a fuse for those particular lights in the kick panel on the drivers side (at least there is on my 04 coupe). I blew that fuse a few months back and it took me forever to find it.
Old Jan 4, 2006 | 11:57 PM
futbol333's Avatar
do you know which one it is...what its called as far as the little kickplate is concerned?
Old Jan 5, 2006 | 12:11 AM
KPierson's Avatar
I believe its labeled 'room' or something like that. Look on the back of the fuse panel door thingy and it will list all the fuses (I didn't realize this until I was putting it all back together). The name will reference either room, int, lights, curtasy lights, or something like that.
Old Jan 5, 2006 | 12:29 AM
futbol333's Avatar
man i tried it and it didnt seem to work...could i have done something else to make it not work?
Old Jan 5, 2006 | 12:39 AM
KPierson's Avatar
What year is your car? Is it a coupe or a sedan?
Old Jan 5, 2006 | 12:41 AM
smknvr4's Avatar
When you put the dash back together did you plug back in the dimming control on the left side of the under dash panel? you may want to recheck it...
I hope I'm not insulting you.
Old Jan 5, 2006 | 12:49 AM
futbol333's Avatar
[QUOTE=smknvr4]When you put the dash back together did you plug back in the dimming control on the left side of the under dash panel? you may want to recheck it...
I hope I'm not insulting you[QUOTE=smknvr4]
naw man...no insults here...we are here to help each other, but yes i did do that and rechecked it...
and my car is an 03 coupe
Old Jan 5, 2006 | 12:58 AM
KPierson's Avatar
There are more fuses behind the battery, but I'm not sure if there is a fuse for the interior lights there or not. I don't have an 03 manual with me, so I can't look it up. The BCM changed from 03 to 04 so you really need the correct manual to look it up with.
Old Jan 5, 2006 | 01:01 AM
smknvr4's Avatar
hmmm. Sorry, just reread you original post. The dimmer control doesn't have anything to do with those...
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
