Where did i go wrong?!?!
Old Jan 11, 2006 | 05:27 PM
BlackG35th's Avatar
Alright, i was up all night last night installing my system!!! like till 4:30..... for some reason my sub isnt hitting hard at all..... like the rear 6X9's are hitting way harder than the sub.... now i have an 04 coupe (6mt if that matters) with the bose system..... i have the jl 10w6v2 with the 500/1 jl amp.... i kno i didnt need a loc buhh i figured what the hell ill just buy one.... so i bought the preipheral svenr its supposed to be for cars that have bose systems.... ok heres my problem i think i could be one of three things.....
1) maybe i didnt tap the right wires?
this is the guide i used to connect the loc
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
2) Maybe i dont have the amp tuned properly? i went to the JL web site and they show you how to tune you amp, but maybe i did somthing wrong.... anyone know what it could be?
3) *** The line out has a swich maybe it needs to be swiched.... to rca or maybe waed.....
any suggestions thanx!
Old Jan 11, 2006 | 05:33 PM
cerr's Avatar
not sure if this will help, but i would start w/ the simplest thing. check and double check your connections, make sure the taps are solid. when your working that late it's surprisingly simple to screw even the easiest things up
Old Jan 11, 2006 | 05:43 PM
ChuckP's Avatar
Turn up the gain on the JL 500/1.
Old Jan 11, 2006 | 06:35 PM
el_duderino's Avatar
Do you have an iPod or Discman? Do you have a mini-headphone-to-RCA adapter (or do you know where a Radio Shack is?)
Is your sub dual voice coil?
RUn your amp off of the iPod or Discman and see if it still sounds bad. If not, you connected your Peripheral wrong. If it still sounds bad, you probably connected your VC's out of polarity with each other.
Old Jan 11, 2006 | 06:47 PM
BlackG35th's Avatar
i think i the amp got a bad tune to be honest...... any recomendations on where each setting should be at for hard hitting but tight bass? i will still do the ipod thing tho.....
Thanx
Old Jan 11, 2006 | 06:55 PM
LP 80 and down.Turn bass EQ off.
Old Jan 11, 2006 | 08:19 PM
jeremyp111's Avatar
A 500/1 should make a 10W6V2 pound hard and most definitely harder than the crappy 6x9's. Here's a few things to check. I've used JL amps in the past and actually have 2 of 'em sitting next to me on my floor. Hope this helps.
1) What is the Input Voltage switch on the amp set to? Try the other setting.
2) Please check how you wired the voice coils of your sub. The 10W6V2 has dual 4 ohm voice coils and can be wired for either a 2 or 8 ohm load. If wired in series, the sub will run 8ohm and parallel will run 2ohm. The 500/1 amp is designed for 1.5 to 4 ohms so make sure your sub is wired in parallel (2 ohm)
3) What type of sub box are you using? What is the interior volume of the box? Not sure if this is a big reason why it's not hitting hard, but subs run best in boxes that have volumes they were designed for.
3) I'm not familiar with the LOC you have. Is it adjustable? If so then set it to the middle to start and turn it up to see if it makes a difference.
4) Check all connections again.
Let us know how you make out.
Old Jan 11, 2006 | 09:33 PM
None of which will help a bit if he wires one channel out of phase with the other.
Old Jan 12, 2006 | 07:04 AM
jeremyp111's Avatar
Very true. Just giving some things to check, that's all.
Old Jan 12, 2006 | 11:58 AM
Yah, I already did that, and it doesn't seem to have helped.
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Visionnn
Oct 3, 2015 05:16 AM
Learned Hand
Oct 1, 2015 09:02 AM
