Coupe Front Speaker Spacer Template?
Old Jan 26, 2006 | 11:49 PM
senupi's Avatar
Speedgeek, When you get it, could you make an quick electronic copy or scan of it with the right proportions? I think this will come in handy for many others as well. Thanks
Old Jan 27, 2006 | 12:00 AM
htn's Avatar
htn
check this out:
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
Old Jan 27, 2006 | 12:08 AM
speedgeek's Avatar
Totally, not a problem. Will Do.
Old Jan 27, 2006 | 08:48 AM
amthar's Avatar
a fairly easy and deadly accurate way of making the template is to take a ruler and measure the distance front the center of one mounting hole to the center of the other mounting hole. Then just use a compass (the type you make circles with, not the type that gets your *** un-lost) to draw overlapping circles with a diameter the same width you previously measured. Where the circles overlap is where your mounting holes are. I did this and got it first try.
mjfenix
Aug 17, 2017 05:49 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
laksjd84
Jul 24, 2015 05:12 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
