Ipod Hook Up Usa Spec Pa11–nis And Pro Clip
#48
#49
ipod hookup
I picked up a 2003 G35 sedan last week and can't stop grinning. I am sold on the PA11-NIS, but am interested on the install. The only DIY install I found shows significant disassembly of the dash. It doesn't look hard, but sure looks time consuming. Has anyone found an easier way to get a PAC or USA Spec unit plugged in without removing the radio?
#52
Edit- Finished! Works fine!! Will post a thread in a few!!
Link to my pics.. https://g35driver.com/forums/audio-video-electronics/86108-installed-nano-w-proclip-w-pa11-nas.html
#54
on
For you 2003.5 owners: I installed the PA11-NIS in my 2003.5 sedan tonight and it works great! It's a bit of a pain to disassemble the dash, but it was worth the trouble...
I used the non-playlist option, so I can flip thru songs with the steering wheel control or control with the ipod directly.
Like the 2005/06 models, the ipod is selected using the CD button on the radio -- it cycles between the indash changer and the ipod, so no functionality is lost. I confirmed that I can still play CDs like always.
Also - the manual notes that an extra cable is needed if you have NAV -- I called USA-SPEC and they told me that was an error. After installing, the voice on my nav works just fine.
Thanks to lalomarquez for the info on the PA-11 and g35ipod.com for the dash disassembly instructions!
My car:
2003.5 6MT Sedan
Desert Platinum
Bose Stereo
Navigation
<<ipod!!!!! (30GB Video)>>
My car:
2003.5 6MT Sedan
Desert Platinum
Bose Stereo
Navigation
#55
#56
Direct mode-- playlist mode
Dude,
If your iPod displays Nissan 0k to disconnect, then you are in playlist mode-- go to page 3 in your manual or see this online manual for details. Move dip switch #2 to "OFF".
i suggest you disconnect the "RADIO" plug prior to changing the dip switch.
Once in direct mode the iPod display will go back to normal and you will be able to use it just as you normally would...in addition to that you can track up/down Fast Forward and Rewind from the radio buttons or from the steering wheel audio buttons--
Works that way in my brothers accord and my girls Golf-- all usaspec pa11 works the same way.
#57
#58
