Amp/speakers
Old Feb 14, 2006 | 06:33 PM
MWhy's Avatar
Amp/speakers
I'm sure this question has been asked before, but I'm having difficulty locating an answer using the search function . I would like to add an amp & swap out the stock speakers on a G35 coupe with the Bose system. Is this possilbe?
If you could just point me to a link, it would be greatly appreciated.
Thanks!
PS Shouldn't something like this be a sticky?
Old Feb 14, 2006 | 09:05 PM
el_duderino's Avatar
It is certainly something that I would think would be a sticky...
The HU output is balanced full range un-equalized. You can use any of a number of amps that will take balanced inputs on their RCAs - JL, Zapco, DLS, etc.
The front speakers are 6.5. Popular midfi speakers are Infinity and Alpine. High end speakers start with DLS UP6 and CDT (there! You happy? and continue to Morel Integra and Elate. Dynaudio, higher end DLS, and others have bigger tweeters than factory provisions aloow, so they need different mounting.
Several members have done this. Just keep looking.
4080 here on this forum makes great sub snclosures that fit right in. They will work with JL and other subs (geeman got a DLS MW110 and likes it a lot).
Where are you geographically? Are you doing the work?
Old Feb 14, 2006 | 10:33 PM
imalazeeass's Avatar
i wish there was a sticky on a complete audio installation. Somebody should make one~!!!!!
Old Feb 15, 2006 | 01:01 PM
MWhy's Avatar
Thanks el duderino!
I'm in Kansas City. I will probably do the work myself if I can find instructions on pulling the door panels, dash, and wiring diagrams for the stock HU(found it). I haven't completely decided what I'm going to do. Usually, just upgrading the speakers makes a huge difference in the way most stock set ups sound. However, if I understand correctly, the stock system runs the speakers at unusual settings(something to do with ohms....I'm somewhat of a noob when it comes to the tech part of this). So I'm not sure any old aftermarket speaker will do. That's why I was thinking of bypassing the stock amp, & purchasing a more powerful one to run aftermarkets on.
Any experience/insight is greatly appreciated!
cv5boi
Oct 29, 2011 09:26 AM
SHOTimer
Nov 11, 2010 09:42 PM
TimW
Mar 25, 2009 08:21 PM
gqong
Oct 4, 2006 11:40 AM
