Help: Tried diabling NAVI when moving with swith
Old Mar 20, 2006 | 10:30 PM
gmoney35c's Avatar
Help: Tried diabling NAVI when moving with switch
I used a separate rocker switch with LED to diable the NAVI when driving. It worked perfectly the first 3 days and allowed me to switch back and forth. Now the screen stays in the disabled mode when moving even with switch on off position. I reconnected the VSS wires and still not working correcting. NAVI is not detecting that the car is moving.
Is it possible that I could have shorted out the VSS wire with a 12volt led rocker switch? Any suggestions will be greatly appreciated. Thanks
Old Mar 22, 2006 | 09:57 PM
Real_G's Avatar
An Army of One...
Why?
Old Mar 22, 2006 | 10:19 PM
gmoney35c's Avatar
So I could used the diabled functions while car is in motion.
Old Mar 22, 2006 | 10:35 PM
Real_G's Avatar
An Army of One...
Doesnt make sense..
You wired a switch to disable the navi so that you could use the disabled functions.
Do you mean you put a switch on the speed sensor wire?
Old Mar 22, 2006 | 11:32 PM
g8tor20's Avatar
FGC's official flip flopper
yes...im sure that is what he meant. Most use the valet switch in the trunk but i guess he wanted a seperate rocker switch.
Old Mar 23, 2006 | 01:00 AM
MechEE's Avatar
How did you wire it up? Check the signal voltages on the VSS wires. When you're stopped it should be 0 or 12 V, and when you're moving it should be about half that (a 50% DC square wave of varying frequency).
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
