Tweeter Install
Old Apr 23, 2006 | 06:18 PM
tantura's Avatar
Tweeter Install
I was just wondering if anyone had installed tweeters in a non stock location? I was thinking of using the defrost (I guess) vents to install the DLS Nobeluim tweets. I would really like to keep the stock look. Any insight would be appreciated! Thanks!
Old Apr 23, 2006 | 07:23 PM
MiloX's Avatar
My primary tweeters are in my kicks. Images great. Soundstage is just a bit above dash level.
Old Apr 23, 2006 | 08:20 PM
tantura's Avatar
Did you flush mount them on the panel or are they stealth mounted? Pics?
Old Apr 23, 2006 | 08:41 PM
badtziscool's Avatar
Here's a pic of his 2nd set of tweets installed by the kick panel. I really can't tell how he did it. It looks like a little pod that's been trimmed to fit the contours of the kicks.
Here's the link to his setup thread:
https://g35driver.com/forums/audio-video-electronics/79113-sedan-install-build-up-pics.html
Old Apr 23, 2006 | 08:56 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Why non-stock location if you want the stock look?
You'll get a better sound stage by keeping them up in the cabin.
Here's what I did to cut my Focals into the OEM location.
Just used a hole saw by hand to cut the plastic.
Attached Thumbnails Tweeter Install-tweet1.jpg   Tweeter Install-tweet2.jpg   Tweeter Install-tweet3.jpg
Old Apr 23, 2006 | 09:51 PM
tantura's Avatar
Hmm, That doesn't look bad at all...
I woulde prefer to keept the stock locations, however I have head that that the higher end DLS tweeters are way too long. The Nobeluims are about 1" long. I just wanted to keep the stock look as much as possible for when it comes time to sell the car.
Thanks for the input!!
Old Apr 23, 2006 | 11:42 PM
MiloX's Avatar
https://g35driver.com/forums/showthread.php?t=79113
Those pods are the surface mount cups that come with the tweets. I have since flushed them into the kicks. I love the way the car images. Especially nice having tweets that play as low as those alpine/scans do.
Old Apr 23, 2006 | 11:56 PM
But you could run into some imaging issues with the tweets and midbass mounted far apart.
Do you have any pics of the flush mount? I saw pics of someone else flush mounting them into the kicks. I just want to see how u did them.
Man. I just bought a chrome PPI PC4400 off of ebay. I just may install my MBs this weekend.
Old Apr 24, 2006 | 12:07 AM
MiloX's Avatar
No pics. I'll take some this week.
I loooooove those old chrome PPI amps. Very simple and understated. It's the one that kinda bows on the top, right? Sorta looks like a really squatty airplane hanagar?
Old Apr 24, 2006 | 10:00 AM
Yup! That's the one!
Old Apr 28, 2006 | 12:40 PM
tantura's Avatar
Ok, so my tweeters came in and they are even bigger than I thought... See them next to the UP6 tweeters!
However the grill will match the stock trim. Does the fitting below look right? semi-stock perhaps.
As far as imagin goes, will it make a difference having them installed lower on the kick panels or next to the 6.5" and should I consider adding/keeping the stock tweeters in addition to the Nobeluim tweeters? Thoughts and insight are appreciated!
Attached Thumbnails Tweeter Install-image_00012.jpg   Tweeter Install-image_00010.jpg   Tweeter Install-image_00013.jpg   Tweeter Install-image_00014.jpg
Old Apr 28, 2006 | 04:27 PM
dR6's Avatar
dR6
Don't mean to threadjack, but if you're looking for a replacement Corner Trim/Sail Panel/Tweeters for your coupe, I have a brand new pair for sale. Check it out in the Marketplace forums:
https://g35driver.com/forums/archived-sales/96961-fs-g35-coupe-corner-trim-sail-panel-tweeters.html
Now back to the thread...
I installed my Infiniti Kappas in the stock tweeter location and it sounds great. Also, it looks completely stock and I highly recommend it if you can find tweeters that will fit.
Old Apr 28, 2006 | 04:46 PM
BigSash's Avatar
^ghey
Old Apr 28, 2006 | 04:49 PM
That actually looks pretty good right there next to the stock speaker. Looks pretty factory.
Only real advantage I see in putting it in the kick panels is that you'll have one less wire to run through the door which is a PITA. Plus, by putting it on the kicks, you'll place more distance between you and the tweets and thus making the difference in the distance between you and the left and right tweets smaller which would help with sound.
But the door panel mounting looks really good!
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
