Can I add subs to my Bose system?
Old May 15, 2006 | 12:47 AM
Jining's Avatar
Hello, I have a 2003 coupe w/ the bose audio, I was wondering is there a way to add subs in? I heard that w/ the bose you cant swap out any of the bose speakers or else it will *** everything up, but you can add sub? I dont know anything about car audio. I was thinking of 2 x 10's I hear good things about eclipse. Hopefully its possible for me to just add an amp + subs to the current configuration, what kind of amp would I need... i dont know anything about channels etc... thanks for the help!
Old May 15, 2006 | 12:58 AM
akachi's Avatar
thx for asking my question.. i need to know about this too.. haha
Old May 15, 2006 | 01:07 AM
truplay8's Avatar
THE BATMOBILE
yes u can add subs
Old May 15, 2006 | 01:08 AM
Jining's Avatar
HOW!!1111 What do we need to get? What kind of amp?
Old May 15, 2006 | 01:27 AM
Jining's Avatar
thx for the help by the way :0)
Old May 15, 2006 | 02:03 AM
osamabinwayne's Avatar
You can use any amp you prefer. If you're looking to only add subs, then a single channel mono amp is good enough. You can tap the signal from the amp to the stock bose unit. I think you should bring it to a shop to install it. It should only cost between 40-60 dollars for installation.
Old May 15, 2006 | 03:07 AM
trackmagic's Avatar
look at my sig. I had those subs and amp installed with everything stock before i got the avic N1 in dash screen
Old May 15, 2006 | 03:42 AM
phenom1011's Avatar
I don't know much about this, but when I called my audio shop they said I need an adapter that costs about 250 so I can control the bass levels for the sub with the stock setup. Does anyone know about this?
Old May 15, 2006 | 08:49 AM
dR6's Avatar
dR6
I'm working on this very project myself on my '06 Coupe w/ Bose. I'll be done once my amp gets here later this week. I'll do a D.I.Y. once it's finished. For now, here's some links to the resources I found helpful:
http://www.g35frenzy.com/forum/showthread.php?t=1044
https://g35driver.com/forums/showthr...ighlight=power
https://g35driver.com/forums/showthr...lifier+install
https://g35driver.com/forums/showthr...ight=amplifier
I hope this gets you started. Do a search in the Audio/Video section and you should find all kinds of helpful tips.
Old May 15, 2006 | 01:39 PM
sliderg35's Avatar
I added a Rockford amp for this very reason. It comes with a wired remote to allow you to control base response. You could use an LOC to convert your input to the amp, but I just fabricated my own. The requirement for that would really depend on what your amp could handle.
JoeMac
Sep 28, 2015 12:28 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
