DIY guide: KPtechnology fog module install
Old Oct 18, 2009 | 01:18 PM
  #61
KPierson's Avatar
85 and 86 are the coil - there must be 12vdc across these two pins to energize the relay.
If you can hear a relay click only with the headlights on then that is the OEM fog light relay clicking, not the KPtech relay. It sounds like your problem is definately between Pin 85 and Pin 86 (although its hard to say which one).
One thing I would also check are the pins in the harness - sometimes if you push the relay back in the socket and it's a little crooked it can push the pins out the bottom.
Old Jan 27, 2010 | 08:07 AM
  #62
blues's Avatar
has anyone ever had a problems with the fog light module on their coup?I've been having these problems and just wanted to know if they are common.I have a manual,when I stall going up on my driveway my fogs will turn off even when the switch is on.I try turning the fogs off that's when the fog lights comes on..just a quick explanation of my problem and just wanted to know if anyone else is having this problem,and if so how did you fix it..thanks.
Old Jan 27, 2010 | 03:38 PM
  #63
matdaddy's Avatar
Are those the 2006 headlights? I dont think so due to the claerance strip being light correct??
Old Jan 27, 2010 | 04:27 PM
  #64
blues's Avatar
yes I do have an 07 coup..took the car back to the installer and they looked at it again and said it might be the module itself?but I don't know..
Old Feb 15, 2012 | 07:47 PM
  #65
jluna's Avatar
I'm sorry but could someone clarify if this install will work on the Sedan or is it just for the Coupes?
Old Jun 17, 2012 | 04:50 PM
  #66
saywat?'s Avatar
Giving this thread a try but was anyone able to get this to work on an 2003 g35 coupe? If so wat'd u do. And for those that got it to work wat year is Ur car?
I'm concluding it doesn't work on the 2003
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
zoop425
Mar 29, 2016 05:51 PM
Freddy07g35
Sep 17, 2015 08:53 PM
yassy
Aug 9, 2015 07:31 PM
attarday
Jul 15, 2015 04:03 PM
