DIY: Easy&Cheap LED Side marker mode...:)
Old Jun 21, 2008 | 12:48 AM
  #61
2drwild's Avatar
nice
Old Jun 21, 2008 | 01:00 AM
  #62
redlude97's Avatar
Originally Posted by darren03
Instead of cutting the marker housing open with a dremmel is it possible to open the housing by heating it up(in the oven) then placing the LED inside? Then using silicone to seal the original hole up. Basically opening it up like you do with headlights.
no, its not held together by the same type of sealant
Old Jun 30, 2008 | 01:29 AM
  #63
GBeast's Avatar
anyone wanna do this for me? ill send you the side markers...
Old Oct 27, 2008 | 11:05 AM
  #64
thanhnike's Avatar
led lights
Originally Posted by chanycrazy
Actually water went in there first time when I used glue to secure the back side of housing..so I tried silicone..It worked really good..No problem at all..
Here are daytime pics
hi could u tell me the part no. on the leds u got in superbrightleds.com and the wires please
Old Nov 7, 2008 | 01:33 PM
  #65
infinus's Avatar
I'm planning on doing this same thing to my sidemarkers and also to my clearance strip, however I want to see if I can Isolate the LED's somehow to give it a more defined appearance so it looks like individual LED's not one long bar, because once you step back you cant really tell that much. I want more of an R8 kinda look.
Old Jan 15, 2009 | 12:53 AM
  #66
NathanJax's Avatar
..... I WIN .....
Great Mod
Old Jan 15, 2009 | 01:02 AM
  #67
blown420's Avatar
oh damn... that looks ****ing sick!
Old Jan 15, 2009 | 01:03 AM
  #68
blown420's Avatar
you should sell them! i would buy it.
Old Jan 23, 2009 | 08:36 PM
  #69
bwam33's Avatar
I just did this cheap LED mod and it looks pretty awesome. However, the LEDs (cool white from superbrightleds.com) don't quite match the stock '05 HID low beams, but it still looks good.
The installation was fairly easy. After getting by the learning curve with some trial and error on the first clear corner the second was pretty easy to dremmel out in order to fit the light bar. To connect the wires to the plugs on the car I simply spliced the wires off the LEDs and fed them into the female connecters of the corner light and secured with electrical tape. I also used the silver marker to color the light bar and waterproofed everything with silicone.
I'll try and post some pics tomorrow.
FYI: I did blow one fuse and the fuse box is located behind the battery. I believe it was the top left one. To get to it, just pop off the plastic molding underneath the windshield wipers and the molding around the battery.
Old Jan 24, 2009 | 05:50 PM
  #70
G SEDAN's Avatar
there are two sets of + and - on each led bar.
only one set of + and - to be powered correct?
Old Jan 25, 2009 | 06:16 AM
  #71
G SEDAN's Avatar
Originally Posted by g35freak86
tried doing this mod. let me tell you, it does not work on the sedan lol. The markers are much thinner and skinnier and cannot house the LED bar. I'm trying to figure out a different way to put it in there but I used a spare set to test fit first.
I got it working on my sedan....used it on my amber spare...tomorrow I will have to duplicate the same process onto my clear clear set.
The variation in level of the light bar is due to the angled corner light in the sedan model. I am going to try and get one side in further to adjust it so it looks as straight as possible
Old Feb 14, 2009 | 01:45 AM
  #72
bwam33's Avatar
I just completed the blinker mod and it works fine with the LEDs.
Old Feb 15, 2009 | 08:55 AM
  #73
risingson's Avatar
will these fit sedan bump corners?
Old Feb 20, 2009 | 09:07 PM
  #74
blk06x's Avatar
Will be doing a set of these in the next week provided parts arrive, then when I have pics, will be offering to do these for people if they do not want to attempt, although it is fairly easy. Will post more info when completed and I will also be working on the flashing in dual colors as well.
Old Mar 25, 2009 | 12:06 PM
  #75
BostonG6spd's Avatar
anyone try the warm white instead of the cool white? i want these to match my 6000K Hid's
