DIY: Ionic Grill Installation
Originally Posted by Karson83
2.) After I removed the four pop-up rivets as instructed on this DIY guide, I found that there are two latches (one on each end of the grill) attaching the grill to the front bumper. I have no f-ing clue how to unlatch these things. This is another thing I found that this DIY did not describe about, I'm not sure if this was because my car is a Canadian one or if it's just supposed to be a "given" that people should already know about? But I sure didn't know.
After you get those clips/latches off, I would reccomend using some of that blue masking tape on the front bumper, and pulling on the grill hard until it pops off.
Good luck!
Originally Posted by mx22o
u need a flathead and poke it into the hole from the front.. turn it and pull it out..
i had the same problem when i first tried to remove my OEM grille
I'm talking about the latches, you need to to turn the top of it so it matches the hole on the bumper.
And I recommend the tape so you don't scratch your bumper from pulling it it too hard and having it pop out unexpectedly.
Thanks!
Thanks!
Ok, after what seemed to be a gruesome battle to the death with my oem front grill, I finally took it off and installed the Gialla replica grill from Ionic. Haaaallelujah!! Haaaallelujah!! Haaaallelujah!! Halleeeelujaaaaah!!
I don't think I did a very good job of it because the lines / spacing seem to be a bit big between the hood and the top of the grill. But whatever, I'm content, not about to take it off and add another layer of tape.
PS. Thx mx22o and Ionic for the tips/advice!!
Here are some crappy pix for your viewing pleasure:
Just installed my Gialla grille, two issues the far right hole needs to have a "rattail file" run thru it for alignment and I used double sided tape on the bottom to make it a little more secure....see not big issues at all.
Gary
Gary
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
