DIY: 7443 Turn signal mod for 06 housings
Old Nov 23, 2011 | 11:11 AM
  #76
DrewTheSuit's Avatar
recently modded my 06 turn signals and am having some problems...i opted to use glass halogen bulbs instead of leds but somehow i am still getting hyperblinking when the indicator is used...to make things more weird, the driver's side will blink at normal speed if no lights are turned on from the stalk but the passenger side always hyperblinks, once the lights are turned on both sides hyperblink yet both sides were wired the exact same way...i will add that i do have oem city lights in but have removed the sidemarkers after i painted the lenses IP...also, one side has a burnt fog bulb that i need to replace...currently only the driver side turn signal illuminates with the parking lights on but both sides worked when i had first tested them, but i also had to replace a fuse in the testing and am currently using a 15A instead of a 10A...any help will be appreciated
Old Nov 30, 2011 | 01:11 AM
  #77
bump, someone help me!
Muski_G
Dec 1, 2023 11:11 AM
yankeefix
Lighting
Aug 24, 2015 04:12 AM
Frostbite91
Aug 20, 2015 07:20 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
