DIY: Refinishing your rims.
Old May 7, 2008 | 09:23 PM
  #61
express705's Avatar
chrome lugs look good with my wheels..
Old May 8, 2008 | 12:02 AM
  #62
dc78chs's Avatar
I did mine a couple of weeks ago and thanks express705 cuz i did what u said to do and it came out pretty good!!! just one tip i would say is sand the inside were the lugs go pretty good bc my paint is starting to wash off everytime i wash my car bc i did a half azz job on that!!! and also be very careful putting ur tires back on!! especialy wene u putting the lugs back on!! other then that is simple!!!
Old May 8, 2008 | 12:04 AM
  #63
dc78chs's Avatar
Old Jul 9, 2008 | 01:40 PM
  #64
lil_leftyy's Avatar
nice post. im gonna do this with gloss black
Old Jul 9, 2008 | 06:53 PM
  #65
express705's Avatar
nice! looks exactly like mine.
Old Jul 14, 2008 | 04:15 PM
  #66
BrocksG's Avatar
Guys just a note, if you are going to change tires and want to change colors you can get them powder coated, a lot harder finish (won't chip, etc) and lasts a lot longer! There are plenty of powder coating shops around that do this type of stuff.
Old Jul 14, 2008 | 04:32 PM
  #67
express705's Avatar
you suck get out of my thread.
Old Jul 24, 2008 | 03:35 AM
  #68
GeeCoupe's Avatar
To get the factory color, would I need to use a black primer with a silver spray?
Old Jul 24, 2008 | 08:48 AM
  #69
express705's Avatar
the dealer will not release the factory color for obvious reasons. dont try to match it, it wont work.
Old Jul 24, 2008 | 07:34 PM
  #70
GeeCoupe's Avatar
Wow that's grimey of them, I think I will use reg silver so I can have some clean looking wheels for the winter. If I remember correctly long time ago someone on the forum had a pretty good match with some sort of silver from a pathfinder... -l'm not sure how graphite would look on a DP coupe so I'll probably just go with silver
Old Nov 29, 2008 | 12:42 PM
  #71
strife's Avatar
Nice write up....
I'm just taggin this for future reference Thanks!
Old Nov 30, 2008 | 09:00 AM
  #72
express705's Avatar
your welcome.
Old Dec 9, 2008 | 12:06 PM
  #73
speedjunkie_G35's Avatar
I liked what ya did so much , I did it myself and I never thought I would be done.It did turn out great though and I've received complements left and right.Thanks for the idea.
When I sprayed them I did the back first ,then went in a circular motion around the outside of the rim's lip, then began on the outer part of the spoke go toward the center cap . Be careful on my last rim the was a slight build up with the clear coat leaving a milky ring around the center cap. Not noticeable unless I pointed it out to you .There like having new rims without the new rim cost
04 DP Cpe , Smoked tails , de-badge , Full greddy BK, w Graphite OEM 17's
Old Dec 24, 2008 | 12:09 PM
  #74
tom's_Z's Avatar
I did my rays in flat black since I have a DG coupe, using your instructions....looks pretty hot, but I am going to try the darkest gray I can get when it gets warmer......since I don't like the flat black look as much as I thought I would. Sanding is a must between coats if you use multiple coats, since light coats tend to come off easily - I used 5 coats, and NO clear. No chipping issues even in the winter with the snow and everything else.
The important thing is getting ALL of the road grime off before painting, which means using an airgun to dry if you want to get started right after washing. Otherwise you'll get lots of flaking.
Old Dec 24, 2008 | 02:16 PM
  #75
GreenGoblin's Avatar
The goblin resurrection
I would have to agree
