Diy: Sticky For Window Motor Repairs/door Panel Removal
Old Oct 20, 2008 | 04:09 PM
  #46
g35man04's Avatar
CLUB MODERATOR
edited the first post to reflect 12mm...Thanks again and congrats on the fix
Old Nov 16, 2008 | 04:02 PM
  #47
drsifu1's Avatar
Staff ALUMNI
20 Year Member
thanks again. fixed the passenger motor today and did the reset.
thank you
Old Nov 16, 2008 | 04:51 PM
  #48
g35man04's Avatar
CLUB MODERATOR
congrats man! thanks for the reply!
Old Nov 22, 2008 | 12:30 PM
  #49
SloM04's Avatar
Thumbs up
My driver-side window started slowing down a few months ago, and ocasionally has stopped responding altogether. Smacking the middle of the door panel would usually help. But the past few weeks, it's been so bad that I would have to manually pull up on the window while using the switch. Sometimes that wouldn't even work. It would even roll down halfway when I'd lock my car. Irritating to say the least. I read your DIY last week and figured I'd give it a try. Considering how bad my window was, I figured I'd definitely need a new motor, not just a cleaning. Well, I am happy to report that I just followed your DIY and it fixed the problem!! Rolls up and down nicely and smoothly now. Thanks!!!! It's much appreciated!!!
Old Nov 22, 2008 | 02:01 PM
  #50
g35man04's Avatar
CLUB MODERATOR
no prob man!! glad it worked out for you !
Old Nov 25, 2008 | 01:22 PM
  #51
cv5boi's Avatar
awesome thanks man!
Old Nov 25, 2008 | 02:14 PM
  #52
g35man04's Avatar
CLUB MODERATOR
no problem man! anything to help out the G35 group with saving money.
Old Dec 5, 2008 | 01:21 PM
  #53
peanut1966's Avatar
i need a pic of the wires that go to the switch went to pull out all the wire came out need help
Old Dec 5, 2008 | 01:57 PM
  #54
peanut1966's Avatar
need help
put the switch off all the wire came out need to know were the pin go back to
Old Dec 5, 2008 | 01:58 PM
  #55
peanut1966's Avatar
pulled
Old Dec 5, 2008 | 04:23 PM
  #56
g35man04's Avatar
CLUB MODERATOR
pm replied...do you mean the window switch wiring harness?
Old Dec 5, 2008 | 04:26 PM
  #57
g35man04's Avatar
CLUB MODERATOR
is that what you are talking about..
Old Dec 9, 2008 | 08:27 PM
  #58
g35man04's Avatar
CLUB MODERATOR
for those individuals who pull out the wires on accident.
here is what I could get.
Drivers side:
Passengers Side:
Old Jan 10, 2009 | 07:53 PM
  #59
ninja1's Avatar
Almost went and spent some money for a new motor, but thought I'd do a little research first. Glad I found this thread. Just cleaned up the motor on my passenger side window because I was having issues (I used a scotchbrite pad to clean the contacts and it looks new again). Went ahead and did the reset process as well. Works flawlessly now.
Thanks so much for the write up and I noticed you're local, so next time I see you I'll have to shake your hand and give props!
Old Jan 11, 2009 | 12:19 PM
  #60
g35man04's Avatar
CLUB MODERATOR
glad to see that you saved money man!! Thanks again for the comments.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
