DIY Replacing Clearance/City Fogs/HID bulbs
Old Aug 16, 2010 | 03:51 PM
  #31
mistuhlayzee's Avatar
just did the clearance strip today using this DIY, was fairly easy to do using the OEM jack that came with my G, the hardest part imo was turning the bulb for the clearance strip back in after changing it, took me several trys. +1 on this DIY
Old Sep 18, 2010 | 02:09 PM
  #32
PoweredbyDragun's Avatar
help different bulbs?
So I did the wheel thing, jacked up the G coupe and took out the panel. I opened up the housing and took out the bulb...and I was shocked to see this kind of bulb (right in pic) instead of the one I bought from infiniti (left in pic) that SAID this is the bulb I need for my car. Do I need to get an adapter? or am I missing a piece? or is infiniti just totally wrong with the bulb they gave me?
Attached Thumbnails DIY Replacing Clearance/City Fogs/HID bulbs-img00788-20100917-1659.jpg   DIY Replacing Clearance/City Fogs/HID bulbs-img00787-20100917-1658.jpg   DIY Replacing Clearance/City Fogs/HID bulbs-img00793-20100917-1700.jpg
Old Sep 18, 2010 | 05:55 PM
  #33
paolotonzini's Avatar
one of those bulbs wit the 3 prong is the h4 fog lite and the other is the projection bulb bro
Old Oct 10, 2010 | 01:35 PM
  #34
DT35G's Avatar
Thanks for the DIY, I just did this 10 minutes ago and this thread really helped!
Old Oct 13, 2010 | 12:03 PM
  #35
hi-tek22's Avatar
isnt the 168 bulb the same as the 194 when replacing as a LED anyway
Old Oct 15, 2010 | 02:14 PM
  #36
R10T_x's Avatar
WOW great DIY and my friend wanted to take the bumper off..... SMH i switched both fogs in about 20 minutes using this method
Old Nov 5, 2010 | 02:08 PM
  #37
jutn35's Avatar
G35 Coupe
Can the Clearance bulb be replaced with an LED
IF SO what kind ?
Old Nov 6, 2010 | 04:46 PM
  #38
NYYBaseball423's Avatar
Would the same steps apply for an 05 Sedan?
Old Nov 13, 2010 | 10:30 AM
  #39
cmjavelin's Avatar
Life saver
I can't thank you enough for taking the time to post that thread. When my bulb burned out, I thought it would be as easy as replacing bulbs in BMW's. Imagine my surprise when, after realizing the headlamp was a single unit, I looked in the manual and it said to take it to a dealer. For a light bulb!
Thanks again.
Old Nov 19, 2010 | 06:43 PM
  #40
icalvint's Avatar
sorry but can someone help me, i dont know how to take out the electrical plug? and its the tanish thing right?
Old Nov 20, 2010 | 01:37 PM
  #41
eelizo's Avatar
I have a 2007 G35S 4d. Trying to replace my fog lamps. Took the air boxes out, no sweat. But can't figure out how to remove the bulb form the housing, Can anybody help? Thx
Old Dec 25, 2010 | 04:14 PM
  #42
infinitlyfast's Avatar
Bulbs
Originally Posted by FargoG35
Where do you get the right ones to fit ?
I know this is an old thread but if anyone is reading it, you can get H4 bulbs for the fog slash high beams in 100/55 100 on high beam and 55 as stock on the fog beam, If it's cold out when you do this, take the tire off and the inner wheel housing to make it easy on yourself. I may post this on my web page for all to see..
Old Feb 6, 2011 | 03:45 PM
  #43
N@eem's Avatar
im having a hard time putting the hid portion back in, the prongs are in the way!!!!!!!!
Old Feb 18, 2011 | 12:22 AM
  #44
PERKS11's Avatar
thanks for this. this should help when i do this over the weekend.
Old Apr 1, 2011 | 03:19 PM
  #45
G. Dizzle #2's Avatar
i JUST got finished installing my JDM Yellow luminics fog lights.... +1 for the DIY w/ pics
