DIY LED Headlight
Old Apr 17, 2010 | 07:02 PM
SCIONMIKE's Avatar
not to my taste what i would do is mount the led hidden so u dont see them, you should just see the glow that will def help with appearance.
Old May 29, 2010 | 12:05 PM
fluffykurt's Avatar
Looks sick
Old Aug 24, 2010 | 04:51 PM
tweger's Avatar
Yeah, I did a writeup of one. Here is the link:
DIY LED headlight thread
Old Sep 23, 2010 | 02:37 AM
sena's Avatar
Old Sep 26, 2010 | 11:40 PM
strapa9's Avatar
what size bulbs do I get for the fog lights? I want to get 3000k hid's.
Old Jan 7, 2011 | 12:14 PM
JoeyDaBoss's Avatar
Originally Posted by morningla
does anyone know if there is a DIY with pictures on how to install LED into the clear strip. and with wiring instructions? i guess that part won't be too hard, i'll just have to test each wire while holding the headlight
not the LED strip that goes along the side of the headlight and shines through, but actual individual LED installed down the center of the clear strip. I'm not sure how you would mount them in place. but actually, i have not even taken out my headlights to look yet.
anyone know what type of LED i should get if i want to match the stock OEM halogen 2004 HID? i assume they are OEM, i just got the car and i didn't see an aftermarket ballast.
i am planning to disable my amber light, and just leave it for signaling.
change the strip to white LED as the DRL.
ignore the high beem and not use it
leave the stock OEM alone and switch off the LED when these are on.
hoping that's possible.
Not sure if this is what your looking for....but I found this..
Guess I was a bit too late lol...my bad man
https://g35driver.com/forums/lightin...ht-thread.html
Old Jan 10, 2011 | 05:08 AM
VincenzG35's Avatar
Originally Posted by pho3nix3871
Red wire to red wire in the side marker light wiring and black to black. It is pretty easy. Connect the side marker wire in parallel with the LED light wires.
all in all its your car and personally i think it looks great just upgrade your headlight bulbs to 6000k to match
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
ENTRAPM3NT
Sep 16, 2015 01:21 AM
twentyeggs
Sep 11, 2015 03:58 PM
