DIY LED Headlight
Old Aug 22, 2009 | 06:23 PM
morningla's Avatar
DIY LED Headlight
does anyone know if there is a DIY with pictures on how to install LED into the clear strip. and with wiring instructions? i guess that part won't be too hard, i'll just have to test each wire while holding the headlight
not the LED strip that goes along the side of the headlight and shines through, but actual individual LED installed down the center of the clear strip. I'm not sure how you would mount them in place. but actually, i have not even taken out my headlights to look yet.
anyone know what type of LED i should get if i want to match the stock OEM halogen 2004 HID? i assume they are OEM, i just got the car and i didn't see an aftermarket ballast.
i am planning to disable my amber light, and just leave it for signaling.
change the strip to white LED as the DRL.
ignore the high beem and not use it
leave the stock OEM alone and switch off the LED when these are on.
hoping that's possible.
Old Oct 22, 2009 | 03:27 PM
breftayka's Avatar
^+1
Old Jan 15, 2010 | 10:14 AM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
bump, i'd like to see a diy of some kind on this aswell.
Old Jan 17, 2010 | 02:12 AM
4DGS's Avatar
A what?
Old Jan 21, 2010 | 04:44 PM
G'dUp954's Avatar
bump!!!
Old Feb 7, 2010 | 11:03 PM
danielj's Avatar
bump again, man i really would have thought someone had a diy on this or something, been searching everyonce and a while, even just on google, can't find anything
Old Feb 15, 2010 | 12:38 PM
twalls's Avatar
CLUB MODERATOR
Here ya go man.. Did it on my blog the other night... It was a breeze really.. And I've never done any kind of electrical mods on my G..
http://blog.rashardanthony.com/?p=184
edit: ah nevermind.. this is for the LED strips if you want to install them in your bumper.. sorry, misunderstood your request..
Old Mar 7, 2010 | 12:05 AM
danielj's Avatar
Anyone?, I'll have to make a new thread in the V35 general section, no one in this section seems to bring anything to light
Old Mar 7, 2010 | 08:11 PM
pho3nix3871's Avatar
Red wire to red wire in the side marker light wiring and black to black. It is pretty easy. Connect the side marker wire in parallel with the LED light wires.
Old Mar 9, 2010 | 02:29 PM
jmueller's Avatar
God that looks bad.. take those out and put them in your trunk, at least then the money wouldnt be wasted.
Old Mar 28, 2010 | 04:13 AM
donut.'s Avatar
No offense man, but LOL.
Old Mar 30, 2010 | 03:04 AM
instances's Avatar
Wow, some people are right..........with a mod like that, the G35 is becoming the new Honda Civic.
All that car needs now is a VTEC sticker!
But, to each his own.
Old Mar 30, 2010 | 02:16 PM
PerpetualVisitor's Avatar
lol it is the civic for the growing middle class
Old Mar 30, 2010 | 02:37 PM
velomack's Avatar
Did you cut your grill to do that? Maybe they would look better behind it, just a beam of light.
Old Mar 30, 2010 | 02:44 PM
velomack's Avatar
OEM Low beam is not halogen. Search around the forum for retrofit / custom headlights. there is a ton of custom jobs out there. There is also a DIY on how to take your lights apart so you can see what it looks like. IMHO buy a second set of lights if you are trying to modify them to that extent. Good Luck!
