DIY: Painting Door Pulls (100% pictorial)
Old Jan 27, 2010 | 12:49 PM
  #31
Swivel's Avatar
Moderator
Hahaha, nicely done. I may do this just so I can chuckle all the way through the work. I got the alcohol one.
Old Jan 27, 2010 | 05:32 PM
  #32
SxSkyLinexS's Avatar
just looked @ this after u posted in "new suede..."
has to be one of the funniest DIY ever
Old Jan 27, 2010 | 05:45 PM
  #33
jknuttila's Avatar
ha doin this today!!!
Old Jan 27, 2010 | 06:41 PM
  #34
NFSP G35's Avatar
? = 2B || !2B
Thanks for the complements guys
Wayne, you wouldn't believe how much stupid searching I had to do to find a decent alcohol molecule
Old Feb 1, 2010 | 03:25 AM
  #35
SacG35's Avatar
good stuff
Old Feb 10, 2010 | 11:54 PM
  #36
socalwdup's Avatar
Hahaha very funny DIY. I will do this later on if I ever need a repaint
Old Feb 22, 2010 | 02:36 PM
  #37
Black Rain's Avatar
question..
i recently just bought two cans of the fabric and vinyl paint and plastic adhesive primer, i am going to attempt to paint everything silver in my car.
will the paint wear off? without a clear or protective coat on top?
Old Feb 22, 2010 | 02:47 PM
  #38
NFSP G35's Avatar
? = 2B || !2B
So far It's been 3 months since I've done mine and it has zero wear. My cousin did his dash with the light blue a few years ago and still hasn't had any fading, so you're probably fairly safe. I do have really dark tint though. I figure worst-case scenario, I might have to repaint after a year or two, but considering it still looks like I did it yesterday and it's three months later, I think it'll last a lot longer than that. I can tell you it's more durable than the crap finish Nissan uses, that's for sure!
One thing though. I wouldn't go near that plastic adhesive primer if I were you. I tried using a plastic adhesive primer on the first parts I painted and it didn't have a smooth finish and the fabric and vinyl coating didn't want to stick to the primer.
Just make sure you use the exact product I showed in the DIY, Dupli-Color Vinyl & Fabric Coating, and be sure to sand all the factory finish off.
Actually, if you're doing the center console too, if you wipe it down with isopropyl alcohol, it'll take most of the factory finish off for you.
If you need any more help, don't hesitate to ask
Old Feb 22, 2010 | 03:48 PM
  #39
Black Rain's Avatar
the local shop near me didnt have the dupli color.. i did get a fabric and vinyl by "rust oleum" in a gloss finish.. what do you think?
  #40
Black Rain's Avatar
can i just sand, clean with alcohol, then few coats of the rust-oleum gloss black fabric and vinyl paint?
Old Feb 22, 2010 | 04:30 PM
  #41
NFSP G35's Avatar
? = 2B || !2B
I've never used the rustoleum stuff, always duplicolor. And the duplicolor is VERY different from any type of "paint" I've ever used. It's almost like spraying ink... really weird, but it works nicely. If I were you, I would try and get the duplicolor. The rustoleum may do fine, IDK. I guess if you used it and didn't like it, you could always sand it off and start over.
Also, you said you got gloss? That gloss will be a little shiny, but won't look anywhere near the "Piano Black" finish that Heist did. I picked up the duplicolor in a satin finish because it's a very nice subtle, OEM type look.
Old Feb 22, 2010 | 10:47 PM
  #42
Black Rain's Avatar
ya, thats what i thought. the spray can gloss paint will be a little more glossy but not real GLOSSY. so it might be a little in between. since i cant decide between gloss and flat ha this could work. guess we will see..
Old Feb 22, 2010 | 11:00 PM
  #43
NFSP G35's Avatar
? = 2B || !2B
I would start with a door pull. They're the easiest part to get off, and the easiest to re-sand and start over if you decide you don't like the finish.
Old Mar 11, 2010 | 10:22 AM
  #44
Kinma's Avatar
Has any one ever tried painting the center console black this way? Would it look cheesy? post pics if u got em.
Old Mar 11, 2010 | 07:39 PM
  #45
NFSP G35's Avatar
? = 2B || !2B
^Actually, I did my console as well. I'm not done with it, still have to get a black shift **** and a DD kit, but it doesn't look cheesy at all.
