DIY - VRT Strut Tower Brace install notes & pics
Old Aug 14, 2006 | 09:00 PM
  #46
Disco_Monkey's Avatar
Originally Posted by inTgr8r
Great stuff, your going to love it!
Take your time with it....
It's a little tricky but well worth the effort.
Yeah it is tricky. I cut my power steering fluid reservoir bracket to fit the passenger side STB brace. I had no problem with the A-Arm bolts and getting the mounts on but then I made the mistake of dropping the car before mounting the bar. I thought the bar wouldn't fit so I called Scott then he told me that the car had to be up off the ground as stated in the instructions. Boy do I feel dumb for that one.
I guess I thought I could force it on but then it looked WAY too long so I couldn't get it on even with brute force, a piece of wood and a hammer. I'm gonna lift the car up and finish up the install tonight. I still have to dremel my CF Z engine cover too.
Old Aug 15, 2006 | 06:42 PM
  #47
amg35's Avatar
Florida G35 Club
Ian, forgive me if I missed it, but did you reattach the power steering resovoir? Thanks.
Old Aug 15, 2006 | 07:57 PM
  #48
Dan_K's Avatar
Will this work with a Vortech? Can VRT PM me a price please, picked up.
Old Aug 16, 2006 | 02:09 PM
  #49
zazaracing's Avatar
Team Transport Member
Dan I asked Scott about this and it should fit they might have to bend one of the monts a little. I have a Procharger and last time I was at the track with VRT we set the bar in my engine bay and it clears but just needs to be installed to know for sure. Ive been laggin on going down to VRT to have them do a test fit.
It should fit im 98% sure
Old Aug 16, 2006 | 04:23 PM
  #50
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes.
I just removed it temporarily to access the attachment point more easily.
Old Aug 16, 2006 | 07:29 PM
  #51
InTgr8r's Avatar
You can get them through Scott .... see below
Originally Posted by 4doorfun!
so where can this be purchased?
v
Old Aug 22, 2006 | 04:33 AM
  #52
Did you have to remove your hood liner?
I removed mine.
Old Aug 22, 2006 | 07:10 AM
  #53
InTgr8r's Avatar
No....
Mine was OK (sedan)
Old Aug 22, 2006 | 02:20 PM
  #54
Ah I see.
Do you think that removing that liner thing will have any effect as far as heat, hood, paint?
Thanks.
Old Aug 23, 2006 | 07:20 AM
  #55
InTgr8r's Avatar
I'm not sure....
I do remember seeing a thread some time ago about some of the functions of the liner.
Old Aug 23, 2006 | 12:51 PM
  #56
Andy2434's Avatar
So, are there existing fitment issues for the coupe with regard to the VRT STB? It sounds like a great mod.
Old Aug 23, 2006 | 05:23 PM
  #57
wa2good's Avatar
Slight fittment issues do exist sometimes. It varies greatly from car to car. I have seen the EXACT same STB put on four different cars with nearly the same mods, they were 3 '04 coupes and one '03 coupe. the brace fit PERFECT on one of the '04's and the '03. As for the other 2 cars, they both had some fittment issues (that were very different from each other), though all fittment issues are fixable, and are usually worked out in a matter of minutes by most people. So, as for the fittment issues, I have found that it is mostly due to variences in the cars not in the STB's.
Old Aug 23, 2006 | 05:42 PM
  #58
vodkarocket's Avatar
Modded Member
I've seen this piece in person and it is definitely very well engineered. After I test drive the car this was installed on, I think I'll be making a purchase as well. There was a very minor fitment issue on the piece I saw, but nothing 2 minutes of dremeling couldn't solve.
Thanks VRT for coming to market with this product.
Old Aug 23, 2006 | 05:49 PM
  #59
machavez702's Avatar
Scott, send me mine so I can use it and show it!!
Old Aug 23, 2006 | 05:59 PM
  #60
Andy2434's Avatar
Get that baby installed by Sunday, Mike. I want to checkout your and Chris' set-up.
