DIY: Akebono BBK Installation on 03-07 G/Z
Old Mar 22, 2010 | 07:38 PM
  #31
The_Dr's Avatar
I have found 2 ways of installing Plate/Bracket.
So...What is the proper way of installing it?
Figure A.
From Dealer. The Plate/Bracket hooks are facing upwards. Highlighted in the red box.
Figure B.
From Forums. As you can see it looks the like Plate/Bracket is inverse from figure A. And the hooks are facing downwards
So What is the proper installation?
Old Mar 22, 2010 | 08:43 PM
  #32
jhurst's Avatar
I have mine where the hooks are facing downward, like in the picture (not the diagram). I'm not even sure if it would fit right if you tried to invert it. IMO, the picture is the correct way.
Old Mar 24, 2010 | 08:58 PM
  #33
jcaramia's Avatar
Sweet little write up.. I would love to do this to my car.
Old Mar 24, 2010 | 09:05 PM
  #34
ntrinsik's Avatar
I did it the way in the photo.. but originally had it the other way. Let me say, it was a lot easier to do it the inverted way..
Old Mar 30, 2010 | 11:00 AM
  #35
MikeGrote's Avatar
subscribed, need to do this
Old Apr 15, 2010 | 11:19 AM
  #36
texasmax's Avatar
Just received my set yesterday, hoping to install this weekend. Awesome write-up- glad I found it!
One question- I've got the SS lines I'm putting on- at the end where the lines connect to the hard lines (not the caliper side, the other side), is it a screw-on connection, or is there any crimping involved?
Old Apr 15, 2010 | 11:58 AM
  #37
ntrinsik's Avatar
Should screw on. No crimping was needed when I did mine.
Old Apr 15, 2010 | 12:17 PM
  #38
texasmax's Avatar
Good to know- thanks
Old Apr 22, 2010 | 10:55 AM
  #39
texasmax's Avatar
Folks that used non-OEM pads- did you use the OEM shims, or the shims that came with your pads? Guessing it doesn't matter thought the rear OEM shims are 2-piece. Using Hawk HPS pads.
Old Apr 22, 2010 | 11:11 AM
  #40
texasmax's Avatar
Yup, the aligning the plate according to the picture sets it in place a LOT better. The one thing is, doing it the FSM way, the two "fingers" on either side of the hook circled in red in the picture give some outward push to the pads, sort of like a spring clip would.
But, it's decision time, so I'm going with the picture, not the FSM!
Old Apr 22, 2010 | 11:28 AM
  #41
texasmax's Avatar
Holy cow, the bracket is flexed SUPER tight when doing it according to the picture.
Old Apr 22, 2010 | 11:40 AM
  #42
texasmax's Avatar
Literally hammering in the pins. I'm thinking the HPS pads are too tall, they're pushing up against the center of the bracket, because once I hammer in the pins, there's still a decent gap between the middle finger and the pin- the pin's only contact with the bracket is with the two outer fingers on either side of the middle finger. This can't be right...
Old Apr 22, 2010 | 12:43 PM
  #43
ntrinsik's Avatar
I went with HPS pads also. Didn't use the OEM shims. The HPS already have them on the pads I believe? I don't recall about the bracket and pins.. I do know it was really had to get the second pin on doing it the way it was in that photo.
Old Apr 22, 2010 | 01:24 PM
  #44
The_Dr's Avatar
I went with the FSM way reason being it should just slide in if you have to force it.. its wrong... shouldn't need to force things and have big gaps to fit. http://www.nicoclub.com/FSM/g37/br.pdf on page 41 to 43 is the akebono installation for the pads.
  #45
texasmax's Avatar
Thanks... and I just ended up going with the FSM approach- the other way just seemed way too "off".
